Nah dude, where it is and the amount being used will just deflect heat from the outside of the partition. Cos i am only doing a partition not a box... good news aswell, its finished and fitted and it turned out perfect so far. ALl came together way better than expected thankfully, as it was a first off attemtp.
I used a piece of cardboard to make a template wall which i taped in place to where the wall will be made, then lined the whole area with garbage bags, then layed around a 2mm thick layer of fibreglass which moulded to the shape of the cooler piping and all surrounding edges. Just gotta get me so neoprene to seal the top edge and a gap down the bottom after i install the cold air feeds but so far its lookn good. I'll try n get mum to bring home the digital camera tomorrow from work to post up some pics.
Just removed the partition again to finish it up, just been down to clark rubber and got me some neoprene hollow tubing which i sliced down the center and fitted to the top edge of the partition to create a good seal against the bonnet. I have also sprayed the inner side of it in black paint, as black is good for soaking up unwanted heat (hence why factory cooler piping and good coolers are painted black). Once this is dry i will wholesaw cut into the inner panel between partition and 1/4 panel in order to run cold air feeds into the partition from same position the factory cooler cold air pickup is located, as the air down low at the front bar is the coldest possible point to obtain air coming up off the ground. Once its all done i am hoping to obtain a heat probe from somewhere to borrow to meausre how low the temp. drop is at the air filter. EVen thinking about having a small Evo style vent fitted above the filter in the bonnet to force cold air into the region. Once thing i'm not sure i fi mentioned but all u surfers would probably know, certain resin's when in a cold environment actually harden and hold in the cold eg. surfboards for strength, this was one of the main reasons i decided to use fibreglass in the first place, and i tested it when i removed it from the liner yesterday by puting cold water on one side of it and puting my hand on the other and the cold litterally soaks through the fibreglass and can be felt almsot the same temp on the opposite side to the water, this is good in that once cold, it stays cold well and with the heat deflecting liner i covered on the other side it deflects heat one way and keeps cold in on the other :P;)
If anyone wants any info at all on what i have done and researched, let me know i'll try and help as much asi can, i should have foto's up asap so ay can see it properly... and also for those who are wondering it has cost me about $40 to make the entire thing, for a moulded fibreglass partition... If ya thinking about doing it but iant sure let me know and i can even give ya hand if its possible :)
No there is the correct size gap left already for it and the piping is there just not visible in the foto. It fits between the headlight and cooler piping then runs down to the front bar, having the piping there meant, not wholesawing like i thought and a snug fit so no hot air leaks, and furthermoremakes sure the air doesn't become warm cos it never reaches the top of encloses area where hot air will sit.
Dude only thin gwith cutting wholes is u lose torsional strength in the panel. U might think i am crazy saying this when the whole is maybe 3" wide and on a panel that seems to do nothing, but tests have been done after wholesawing panels for weight reduction and the srength loss is huge!! Just be careful where u cut the holes from.
P.s. Still been looking round at other partitions people have done and one's that are being sold for around the $150 price such as the UAS one, and to tell ya the truth the simpler the better. The UAS one is just simply on sheet of neoprene cut to fit perfectly as a partition, would be around the $10-15 price to constrcut and i have a top view photo of an R33 one from the net which i am currently working on in scale to create an exact replica of it. Once its done i'll post it on here and EVERYONE can have cheap good working partitions :).
Hey _turtle_ is all finished, i have run the cold air feeds and made an alloy funnel which also feeds cold air form the stock ram tube thingy.l Works great, a lot smoother rev's, especially last night was nice and cold at 3am and was alot better. I wanna try n chuck it on the dyno with and without the partition in soon and check the results.
A partition type sounds pretty good, (to block the heat coming from the engine/turbo) but i don't see why some people are making closed boxes with a opening going down near the front bar area. Isnt the idea of a pod filter to be able to suck air from 360 degrees around it rather than through say a 3inch pipe?
Also in rain isnt water going to be flying up into your custom pipe being so low to the ground. One more thing, who says the air down low is colder, have you tried walking bare feet on the road on a warm summer day? It gets farken hot and that makes the first few inches or so of air near there pretty warm too. Im not here to knock your ideas but there seems to be a few faults in the common beliefs. I am mainly researching so far so i can make up my own partition set up, as i have a unifilter trumpet style intake which is pretty damn big. Pick away at my thoughts here as i'm open to everyones theories.
the heat still gets through the partition, with the closed box u ensure that it isn't sucking any hot air at all.
3" pipe is sufficient enought to bring in cold air to the filter. instead of leaving it exposed to the engine heat and sucking that in from all directions.
at the end of the day i guess the air coming in from piping is colder than heat from the engine.
dunno about the rain, depends how big the puddle is i guess and how low ur intake is.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
