Ive been following this thread with some interest cos I spent a bit of time building and perfecting a cold air box with pod inside.
I'm reading lots of posts here where people are going back to there standard box with a better brand of panel filter installed and all seem to feel that the result is superior to the pod set up it relaced. Now this may be the case, but if you want to compare apples with apples then you should take the time and effort to set your pod up properly in a fully enclosed and insulated box with a good cold air supply.Only then will you get results worth comparing, and believe me, you will never use panel filters again.
I have enclosed pics of my set up to give those of you who are keen a bit of an idea.You will see that cold air can enter the box thru the original snorkel, under the leading edge of the lid, and thru behind the headlight where the rubber has been removed.
Pod is blitz. Results are worth every bit of the effort.
Cheers
Harry:cool: :D
Well, I got a GTR with standard cooler so there aint much room. At the moment I run HKS pods but am looking at K&N but there just aint that much room for long filters. Anyhow I woudlnt mind some sort of partition but not that keen on putting together a dodgey amatuer job that I would do. Even if i did partition it, not sure if I should try & squeeze a decent intake somewhere.
any feedback would be good.
Cheers,
Penfold
Originally posted by mtopxsecret6
What material would be best used to make a box for the pod filter? IM thinking for reflecting heat away? Fibreglass? metal?
I used ali sheet ( about 1 mm I think) and lined it with a sound proofing product that plumbers use to wrap soil pipes in multi level appt. situations. It is a thin foam backed with a silver foil and lead laminate. You should be able to pick it up from a plumbers supply outfit.
Hope this helps
Cheers
Harry:cool: :P
With the argument for heatsheilding the turbo piping.
how about just doing the intake from filter to turbo, then from intercooler too plenum?
or better yet, getting a set of temp probes and seeing how hot the air inside the various parts of the plumbing is compared to ambient??
surely that would settle the heat sheild debate....
  • 4 months later...
  • 3 weeks later...
I made one up for my HKS pod filter a while ago.
All the details can be found here
http://hyperwa.com/sau/cai/
And the attached pic is what it looks like once all done.
Post up here if you've got any questions :rofl:
J
P.S. - have a read through the Word doc on the link above, it might answer your questions.
Could you send me an actual pic of you CAI please.
I am looking to do one soon thank you
JT
Making a good CAI partition is easy if you have the know how, and the key to success is profiling it to the bonnet and feeding as much ambient low pressure air to it.
To make a template for ANY car
Use regular packing carton cardboard (3 layer is good) & scissors to make a rough template. (more can always be cut/taped back on to perfect it).
once you've got your shape right, cut out your holes for AFM, pipes/cable etc stick brads or short lengths of wire into the top edge of the partition(i.e the cardboard "sandwich" construction holds em in place.)
Close the bonnet - open the bonnet. Voila ! you have profiled the bonnet. Now make a template from this & play connect the dots. subtract 5mm or more from the bonnet edge.
Use tin snips or metal shears to cut your crazy ass shape.
Clark Rubber sell all sorts of edgings for sheet alloy. For the top i prefer 3/8" pipe lagging. It's cheap $2-3, closed cell & moulds perfectly to the underbonnet.
A bit tricky to describe without pics but the principle is the same as that executive toy with all the metal pins that would profile a face or other 3D object. Very popular some years ago.
Seriously I have done this for 3 different cars now and the results are awesome. In a Skyline: use the factory snorkel - it's bloody good; remove the rubber flaps from the headlight harness & the rubber strip that seals the bonnet against the headlight. If you can use one of the I/C piping holes, even better. You don't need to ram air in there, just make it easier to breathe lots of cool air
I'll try to find some pics...
hope this helps out.
  • 5 weeks later...
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
