PashaK Posted December 10, 2004 Share Posted December 10, 2004 i dont have a sample schematic. try making one out of cardboard, get it to fit the way you want it. then trace it onto paper and send it to me Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1118525 Share on other sites More sharing options...
someonestolecc Posted December 14, 2004 Share Posted December 14, 2004 Trace it onto paper you say. Will do - might take me a week or two tho. Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1122636 Share on other sites More sharing options...
PashaK Posted December 14, 2004 Share Posted December 14, 2004 might not have a week or 2 as ive aplied for a few new jobs and if i get offered any i will no longer be a laser operator... Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1122651 Share on other sites More sharing options...
tang0 Posted January 19, 2005 Share Posted January 19, 2005 Was about time i got around to making a CAI box for the car ... and had a couple of hour spare today ... went upto the local mitre 10 and bought a sheet of 600 x 600 aluminium, this was about twice what i actually needed. They were out of pop rivet guns, so had to use nuts and bolts with spring washers anyway, roughly measured what i needed, cut out a cardboard box to the rough size, tried it, trimmed it a bit, repeated this a few times, and came up with a good size, transposed this onto the ali sheet, and cut out, the top was just made by roughly cutting out what i needed, then placing it on top of the vertical sheet now in the car, and drew around it with a marker pen, cut it out, then cut lots of small cuts along the edge so it could fold over and bolt upto the ali part easily. Bent the lip of the top, drilled holes, bolted up, and sprayed with some heat resistant paint, slotted it all in place, and used the headlight mount to bolt it down .. i cut some fuel hose long its axis and slotted it along the bottom, this is just to stop the ali sheet scratching the inner wheel arch. The bottom of the vertical part os bent in slightly to avoid the pipe going down into the FMIC from the turbo. As i have an FMIC the pipe that the std intercooler would return to is not there, and so is basically a 2.8" hole to behind the indicators (its s series 2) so i have a nice cool air feed to the inside the box .. see pics below www.host32.com/line/cai/DSC01946.JPG www.host32.com/line/cai/DSC01947.JPG www.host32.com/line/cai/DSC01949.JPG www.host32.com/line/cai/DSC01950.JPG www.host32.com/line/cai/DSC01951.JPG This last pic is a view from the front nearside, behind the indicators (cameria is in the hole under the indicator) you can see the hole that feeds the cai. all in all took about 3 hours, will get around to putting a window in the top at some point when i can be arsed. No idea if its made any difference to performance, but it certainly cant hurt ... roll on the 550cc inj and pfc tune Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1167911 Share on other sites More sharing options...
geno8r Posted January 19, 2005 Share Posted January 19, 2005 Very tidy. Feel like making some cash Tang0 ? Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1167987 Share on other sites More sharing options...
tang0 Posted January 19, 2005 Share Posted January 19, 2005 thanks ! the thing about building them is i'm fairly sure each box will be slightly different due to different positioning of the afm ... mine is totally not a standard position as i made up my own aluminium support brackets for the hks pod ... Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1168107 Share on other sites More sharing options...
FATAZZ Posted April 19, 2005 Share Posted April 19, 2005 i just made cardboard cut-outs of my partition around my air filter,wot material do u thinks the best 2 use? Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1307214 Share on other sites More sharing options...
PashaK Posted April 20, 2005 Share Posted April 20, 2005 im still a laser operator by the way. so send any schematics my way so i can get them cut on the laser. thx Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1308820 Share on other sites More sharing options...
Pulp Posted April 26, 2005 Share Posted April 26, 2005 Basically it will be a box extending from just under the guard lip on the right covering all the filter and cooler piping, and drop straight to the floor next to cooler piping and will be all polsiehd and look fancy etc aswell as serving its purpose. Everyone who is interested please PM me and tell me, as i have to do these in my free time at work (lunch time, friday arvo's) so i don't want to be wasting time. It will probably work out around $80 each plus shipping? Sound good? Polished alloy, ready to fit... Let me kno, i'll do mine in the next few days n post pics then you can see. Hi YBSLO4, just wondering how you ended up going with the new box? Wouldn't mind seeing how it looks and if you think it made things better. PM me if you like. Cheers! Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1320342 Share on other sites More sharing options...
Eug Posted May 7, 2005 Share Posted May 7, 2005 original airbox was too restrictive with the panel filter. installed a pod filter a while ago to my NA it was an improvement, but it was just sitting there and seemed very sluggish due to the heat from the engine. I then decided to make a heatshield to try and make the most of it. template was made with cardboard - made about 3-4 of these, continously trial fitting. transferred the cardboard template onto aluminum sheeting mounted brackets to hold the sheeting in place insulation foil on both sides to keep engine heat away from pod. I have yet to do a temperature check, but after a fairly spirited drive for 20mins, and placing hands on either side of the heatshield - a large difference in temperature was apparent. This was done on a under ~$30 budget - i took my time in doing it - but can be done in a few hours. End Result: Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1338960 Share on other sites More sharing options...
thirtythree-II Posted May 27, 2005 Share Posted May 27, 2005 Did you notice much of a difference in performance? Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1376066 Share on other sites More sharing options...
Eug Posted June 1, 2005 Share Posted June 1, 2005 http://www.skylinesaustralia.com/forums/sh...ead.php?t=74355 refer here for more details... dyno charts show before and after effects and a full write up on what changes i felt in driveability. Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1385470 Share on other sites More sharing options...
CONRAD Posted June 3, 2005 Share Posted June 3, 2005 Hi Guys, I currently planning on making a cold air induction system for my 32 gtr. I envisaged buying a standard air intake snorkel (as my car came without one) feeding that into a cold air box as well as trying to fabricate some sort of wide tubing running into a fiberglass funnel to fit the box through the awkward oval hole shown below: I can only find R32 gtst snorkels so how do they differ, if at all, and does anyone know if an the gtst snorkel will fit the GTR mounting holes etc? Also, I鈥檇 imagine that cutting sheet metal is a BIG NO NO incase of defects etc, though the hole shown is a tad small, what do you guys think.. and what are other peoples methods of feeding air in without cutting metal or drilling holes?? Help appreciated, cheers. Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1388909 Share on other sites More sharing options...
Eug Posted June 3, 2005 Share Posted June 3, 2005 sounds good.. just be weary of water going in... Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1388991 Share on other sites More sharing options...
FATAZZ Posted July 3, 2005 Share Posted July 3, 2005 how does everyone elese remove the passenger headlight? those bolts down near the radiator are impossible Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1444507 Share on other sites More sharing options...
Pulp Posted July 7, 2005 Share Posted July 7, 2005 http://www.skylinesaustralia.com/forums/sh...ead.php?t=74355refer here for more details... dyno charts show before and after effects and a full write up on what changes i felt in driveability. Hi mate, Just a question, I know you said you used aluminum sheeting, it looks quiet thick though, is that all you used? I'm just getting ideas at the moment. Cheers! Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1452972 Share on other sites More sharing options...
Eug Posted July 8, 2005 Share Posted July 8, 2005 its an aluminum sheet, then on both sides stuck with a foam layered foil type thing (courtesy of 51jay) - can be picked up @ clark rubber or something similar. does the job, keeps the hot air out, and limited to the heat shield. engine bay || foil/foam || aluminum sheet || foam/foil || pod filter ^^^^^layers are pretty much like this ^^^^^ Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1453216 Share on other sites More sharing options...
MearCat Posted July 8, 2005 Share Posted July 8, 2005 I've used 2mm Ally but I think the benefit comes not from the aluminium but the foam foil layer. Eug - to take your example, I have this setup : engine bay || foil/foam || aluminum sheet || pod filter ^^^^^layers are pretty much like this ^^^^^ without a scond layer or foam/foil and according to my temp gauges, it keeps the intake temp within 2-3 degrees on ambient temp when cruising. Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1453301 Share on other sites More sharing options...
Pulp Posted July 18, 2005 Share Posted July 18, 2005 its an aluminum sheet, then on both sides stuck with a foam layered foil type thing (courtesy of 51jay) - can be picked up @ clark rubber or something similar.does the job, keeps the hot air out, and limited to the heat shield. engine bay || foil/foam || aluminum sheet || foam/foil || pod filter ^^^^^layers are pretty much like this ^^^^^ Thanks mate! I'm in the process now of cutting out a template and getting the right fit. Thanks again! Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1470549 Share on other sites More sharing options...
fob2nv Posted November 20, 2005 Share Posted November 20, 2005 he he he he Link to comment https://www.sau.com.au/forums/topic/13003-cai-partition-diy-information/page/9/#findComment-1730660 Share on other sites More sharing options...
