How Low Is Your R33?
Hey Ladz, im after some new suspension but not really going for the whole coilover setup right now, but show me pics of your car and tell me what suspension it has?
specifically looking for Lovell Super Lows All Round.... but show me anything you have, maybe ill like it and go for it...
just so i get an idea of how it sits..
Beef
Edited by Beef
My R33 is 350 ctr of wheel to guard pretty much all round. This is using A'PEXi hard tune down springs (3.6kg/mm front 3.4kg/mm rear) with Sydneykid's bilstein shocks on the standard settings. Must say ride is perfect for my liking even though I didnt use the whiteline springs that was recommended with his package.
I wouldnt want to go any lower with my Nismo bar though, so im quite happy with the height.
Rear sits lower just the way the guards are cut. Look at a VN Commodore. Rear can have a ride height 50-60mm lower than the front. Measure the sil panels and it will probably have a fairly level height. Just my 2cents.
Regards
Brad
mt front lip sits 50mm off the ground, has koni adjustables all round
50mm off the ground? that is rediculous.
mines about ~115mm off the ground, 350mm front centre to guard, 340 rear centre to guard.
running HA teins
i dont know what kind of suspension i have. how the hell do i tell? there's nothing written on it, that i can see.
also, i know coil overs are coil over shock, but isnt standard R33 coil over shock aswell?
hmmm, preeeez exprain.
anyways, mine sits at about 335 front, 340 rear.
from bumper is about 105mm off the ground.
Raed this Monkeyb0y Coilover FAQ
Yes it is :happy:
i know, it's obvious, but why do people ask me if i'm running coilovers?
duh'
i'm not running leaf springs, am i? lol
in my first post, i said i dont know what i have, as in which brand. i guess unless there's a big f**k sticker on there, you'd have to pull them out to find out.
It's just a difference in interpretation. Most people consider coilovers to be an off the shelf/direct bolt in arrangement that have a threaded shock section and can be height adjusted with a "C" spanner.
In actual fact it generally just means the coil spring is fitted "over" the shock absorber.
I guess Technically they should be called:
Coil Overs
Height Adjustable Coil Overs
Damper Adjustable Coilovers
Or both.
i think my front lip is round 90mm-100mm clearance, no idea what centre or wheel to arch is? mine sits on full adjustable TEIN HA's, any lower than it sits now an its just damn annoying, can't go in driveways, through drive through etc....I can bearly do it now at the height it is.
King Springs use centre of rim to guard measurements to rate there springs, just rim em up an state you want 355mm front an 345mm rear, they'll have something pretty close, give you the part number, then just go into your local repco tell em the part numbers an order em :(
rear is usually set lower to increase the amount of weight balance that sits over the rear wheels it increases traction and makes the car handle a little more neutral then the standard front-heavy. and when breaking for a corner usually saves you a bit of understeer.
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
