R33 Misfire, Just Changed Exhaust
Guest Rotary20B
Just changed cat to a high flow magic, and a trust cat back exhaust.
Now up around 5-5500 rpm the car will always misfire, only happens at high rpm, would it be because it is running too rich?
This is the only mods the car has apart from a pod, it never did this before the exhaust change.
Any ideas? I did reset the ecu as well.
https://www.sau.com.au/forums/topic/130080-r33-misfire-just-changed-exhaust/
Hey mate, because you have upgraded your exhaust the car will actually boost more, the problem you mention sounds like youre spark plug gap needs to be reduced to cater for the increase in air going through youre motor. Drop plug gaps down to about 0.8mm, should solve youre problems.
Bigger exhaust = more air out, which means more air has to go in ;)
Guest Rotary20B
Well I changed plugs, bought a new set of copper plugs and regapped them to .8
I didn't want to tape the coils as I couldn't see any cracks at all.
It worked fine on stock boost, then last week I fitted the turbotech boost controller, 10 psi and it would misfire, turned it back down to 7psi and no misfire.
A week later and now it even misfires at 6psi.
I really couldn't be f**ked playing around with taping coils and would just take the plunged and buy a set of splitfire coils if I knew for sure this would fix the problem, any ideas?
Tape them up now to be sure. It's only an hour job. If it fixes then you will know its definitly cracks in your coils...then you can choose to seal them more permantly with silicon or "just buy splitfires". $5 Vs $550.
Same thing happened to me and I could not see any cracks at all...but apprantly they were there coz silicon fixed it.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
