Item: 1991 TOYOTA STARLET GT
Website: CARSALES
Item Condition: VERY GOOD
Reason for Selling:
Price and Payment Conditions: $18,900
Extra Info:
Pictures:
Contact Details: 0403710821
GT Starlet 1991, Engine Mods- 1.3L - Full Rebuild, new forged pistons, forged rods,head studs, copper head gasket, o ringed and block, new bearings,HKS T28 Hi flowed turbo, Custom Mainfold, 2.5inch Exhaust into 4inch canon, Bigger injectors, Bigger fuel pump, Autronic computer, 38m Turbosmart wastegate/ with screamer pipe, Apexi air filter, Front mount intercooler, Type III blow off valve, Boost controller, Chromed rocker cover,Suzuki swift GTi radiator, Heavy duty clutch - Motor is ready for nos, built to run big psi, Never boosted over 12psi, Safe tune. Exterior- Full custom pink pearl respray, Custom air brushing, Full custom body kit- Front bar, side skirts, rear bar, eyelids, m3 mirrors, Light window tints. Interior- Full retrim front and rear seats in yellow mixed with swade inserts, Tv screen insterted in rear seat,Door trims done, roof lining, dash retrimmed, parcel tray with engraving [GT], Chrome Boost guage, Air/Fuel Ratio guage, Shirt light, Monstor tacho on dash, F1 Steering wheel. Sound- Pioneer 6x9s rear, Pionner 600w amp, Sony Xplod cd player. Tv screen insterted in back seat. Rolling stock- 17inch Gestalt Virouge 205/40 tyres, Koni coilovers, Adjustable suspension, Koni front and rear sway bars.. Car is also engineered. Have all recipts of all work carried out. Spent over $45,000. Many more mods done that ive missed out. Never been in any accidents, inspections welcome. Very quick car., and a REAL HEAD TURNER!
SORRY 4D PIX GUYS.
ILL GET SOME PROPER ONES DURING THE WEEK.
THATS JUST A ROUGH IDEA OF WHAT IT LOOKS LIKE.
Edited by UL11KE_180
  • 1 month later...
bump! price drop $17,900
1year rego
brand new clutch.
dyno sheets also- 135kw@10psi
over 200kw atw@18psi
new pix from toyota fest. last sunday
also open to swaps with cash my way
let me know what u got.
intrested in gtir,180s, 200sx, skylines.
car is complete, nothing to do. real head turner and one of the qikest cars around.
  • 4 weeks later...
  • 1 month later...
  • 3 months later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
