Item: 1991 TOYOTA STARLET GT
Website: CARSALES
Item Condition: VERY GOOD
Reason for Selling:
Price and Payment Conditions: $18,900
Extra Info:
Pictures:
Contact Details: 0403710821
GT Starlet 1991, Engine Mods- 1.3L - Full Rebuild, new forged pistons, forged rods,head studs, copper head gasket, o ringed and block, new bearings,HKS T28 Hi flowed turbo, Custom Mainfold, 2.5inch Exhaust into 4inch canon, Bigger injectors, Bigger fuel pump, Autronic computer, 38m Turbosmart wastegate/ with screamer pipe, Apexi air filter, Front mount intercooler, Type III blow off valve, Boost controller, Chromed rocker cover,Suzuki swift GTi radiator, Heavy duty clutch - Motor is ready for nos, built to run big psi, Never boosted over 12psi, Safe tune. Exterior- Full custom pink pearl respray, Custom air brushing, Full custom body kit- Front bar, side skirts, rear bar, eyelids, m3 mirrors, Light window tints. Interior- Full retrim front and rear seats in yellow mixed with swade inserts, Tv screen insterted in rear seat,Door trims done, roof lining, dash retrimmed, parcel tray with engraving [GT], Chrome Boost guage, Air/Fuel Ratio guage, Shirt light, Monstor tacho on dash, F1 Steering wheel. Sound- Pioneer 6x9s rear, Pionner 600w amp, Sony Xplod cd player. Tv screen insterted in back seat. Rolling stock- 17inch Gestalt Virouge 205/40 tyres, Koni coilovers, Adjustable suspension, Koni front and rear sway bars.. Car is also engineered. Have all recipts of all work carried out. Spent over $45,000. Many more mods done that ive missed out. Never been in any accidents, inspections welcome. Very quick car., and a REAL HEAD TURNER!
SORRY 4D PIX GUYS.
ILL GET SOME PROPER ONES DURING THE WEEK.
THATS JUST A ROUGH IDEA OF WHAT IT LOOKS LIKE.
Edited by UL11KE_180
  • 1 month later...
bump! price drop $17,900
1year rego
brand new clutch.
dyno sheets also- 135kw@10psi
over 200kw atw@18psi
new pix from toyota fest. last sunday
also open to swaps with cash my way
let me know what u got.
intrested in gtir,180s, 200sx, skylines.
car is complete, nothing to do. real head turner and one of the qikest cars around.
  • 4 weeks later...
  • 1 month later...
  • 3 months later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
