Hi all,
I brought a R33 this weekend and having to drive it home (1000km) it was so loose in the back end like a big bump in the road and it felt like a trampoline, the back end just about lifted of the ground. It seems really really soft and im a little confused why. Maybe im dump but yeah.
This is what i was told was in the car "Gas shockies (Gab suspension)" Can this be pumped up or what????
Im picking the the shockies are gone but looking at them they look nice and new still shinny paint on them
If anyone can help out, that would be great cheers
https://www.sau.com.au/forums/topic/130098-bouny-back-end-why/
gas shocks don't need pumping up, they are supposed to be a sealed unit.
maybe they are simply set too stiff, so when you hit the bump rather than the shocks absorbing it they pushed the car up into the air, and then the back wheels came down hard.
even in totally stock form the back end feels quite lively, so with stiffer shocks i'm sure it would be a problem!
My pulsar and skyline do the same thing.
I noticed with aftermarket suspension, the rear will bump and kick a bit on rough roads.
I was informed that making it a little stiffer in the rear would get rid of this because the rear was under shocked. Dont know how true this is or how well it works. Have only just set the rears stiffer so will have to wait and see.
What happens when you "bounce" the rear end of the car? How far can you push the back down when you lean on it? What happens when you release the load?
If you get it bouncing, it should stop within 2 bounces - otherwise the shocks are shot.
If you have no joy with the responses that you have heard, i have noticed with cars that are "lighter in the back end" than normal cars, to run a slightly lower tyre pressure in the rear wheels, see if this helps, i would recomend about 32 - 34 in th rear and about 36 in the front. see if that helps with the bouncy effect.
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
