Finally got all my parts in and took the car to the dyno and the results were less than I expected (although, isn't that always the case :(). I was under the assumption that the HKS GT2530s would spool much much faster than they did and I was expecting around 450 whp. Let me know what you guys think..
A/F ratios: started off weak but were spot on after moving around the fuel map and we peaked injector duty at only 74%.
Boost: we went up to 1.4 bar to play it safe on the GT2530s, and when it finally got to full boost, it held steady there moving around +/- .2 bar.
Power Mods:
2 x HKS GT2530 Turbos
2 x 300zx MAFs
Ogura Twin Plate Clutch
Greddy Front Mount Intercooler
Sard 722cc Fuel Injectors
Sard 276lph Fuel Pump
NGK Iridium Racing Spark Plugs
Apexi PowerFC Stand Alone Engine Management
Apexi PowerFC Boost Control Kit
Apexi PowerFC Commander
Greddy dual dump pipe /w decat
Apexi exhaust damper control
5Zigen Exhaust
Notes: Dyno sheet is in yankee hp not aussie :). It was done on a RWD dyno with AWD fuse pulled, no AWD ones around here. Normal pump fuel was used the whole time.
Not sure why it's showing the image as dead below, but it opens when you click it.
Edited by berzerkled
is there a graph with boost pressure against RPM? torque peak at 6500 seems to be like it's very laggy, guessing it doesn't hit full boost until after 5500.
Thanks for the replys guys..
CAMs and what is normal fuel over there. we use 98 or 100 RON over here.
The 91 I was using is spot on to your 99.
I don't have any sort or graph, but yeah full boost was very very slow. I'm thinking it's one of three things:
1) I have the PowerFC (PFC Boost Control Kit installed) set for 1.4 bar @ only 60% duty, should I bump up the % and lower the boost I'm asking for?
2) The actuators are way off on the turbos for whatever reason and just need to be tightened? I don't know if the gt2530 actuators can even be tightened..
3) Boost leak?
I really have no clue on this one, just throwing some ideas out there.
Thanks again guys.
they use 91 octane, there premium is around 94. Still far to laggy something must be wrong
Their octane ratiung however is calculated on RON+MON/2, whereas ours is just RON.
American 91 octane is basically equivilant to our 98 octane, and the 94 octane well surpasses out premium fuels.
Edited by Amaru
Well something is definatly wrong.. I just did a 13.09 @ 105mph in the quarter mile, with a peak boost of 1.35 bar and everything appeared fine on my Apexi Commander.
So my only 2 thoughts on what could be wrong:
1) The actuators are way off on the turbos for whatever reason and just need to be tightened? I don't know if the gt2530 actuators can even be tightened..
2) Boost leak?
Any ideas?
we saw 404awkw (540awhp) on pump gas with a similar set-up and over 450awkw on race fuel...what total timing are you running?? with correct camshaft selection and tuning there is no reason why you shouldn't crack 350awkw (470awhp)
AFAIK Mustang Dyno's read pretty damn low?
The 1/4 mile dyno didn't lie though 13.09 @ 105 MPH
our car was the test car in HPI way back when it was bog stock and i think Ben Ellis managed to reel off back to back 12.9's
I'm on stock cams and cam gears. I know that will slow spool but it shouldn't be nearly this bad.
I had another GTR last year and pulled nearly the same time as this one..which has the hks 2530s.. this doesn't add up.
