I did a search around and couldnt really match up any info on CV joint maitenance for r32 GTR's.
I have the slightest Clunk developing in one my front right CV joints decelerating , turning and really wanting to fix the problem. (sounds like a Camira)
Whats involved with this maintenance ?
Some other threads in other forums on different cars recommend doing the whole assembley where others just change the faulty joints etc.
Should i do both sides?
Do i have to Chase up Nissan Genuine bits or is there a stronger upgrade Available?
I thought i would ask here as i have been caught out by bad advice from mechanics that didnt know or guessing with this import in my area.
Thanks again
https://www.sau.com.au/forums/topic/130147-nissan-gtr-cv-joints-maintenance/
Thanks again
Ive had a few of these things fail and take the driveshafts with them.
Get your wallet ready.
Best thing to do, is order a new CV joint (Inner is around $230 or so delivered depending on the discount you get from club affiliation etc) and the boot kit for $58 and get it installed, then throw the old one out. Driveshafts, new, are in the $900 mark also depending on discount etc
As for maitenance, just have a look once or twice a month to see if the boot is cracked or split, if it is, get it replaced - easy
  • 4 weeks later...
Can some one please help me with a dealer or a Contact that stock's the cv joints and boot's etc for the r32gtr ... No one in albury / wodonga has any part listings or any idea of who to source and its driving me nuts.
I want it fixed so bad!
thanks
Ok, what you need to do is get the rubber boots, and the actual cv joint :O
PM "Slide" he can get that stuff for good prices, and it will be delivered to you, so then its a simple swap - toss the old one and in with the new one
Or, if he cant help, ring PowerPlay Imports in Drummoyne and ask them to order the bits for you, they've ordered those bits before for my car - if you have to remind them just say its the same as Steve's white GTR
If you have any trouble, PM me and ill see what else i can do
This is a bit Scary!!! Have the R32's GTR spares ceased Altogether?... I have spent 2 days chasing part's for this maintenace and every nissan dealer i have spoken 2 has told me that they cant be boughtand none are in there system. Not even the whole assembly..
The CVjoint man's supplier dosent have them either
I managed to get the tech drawing from nissan.
which shows the whole shaft and the repair kit with part numbers .
Stessing!!!
Surley someone has / is haveing the same Cv joint problem.
What should i DO ?
EDIT! thanks N1GTR i hadnt read your reply before i wrote this PLea? u caring Bear you :O
Edited by ishh
Stessing!!!
What should i DO ?
EDIT! thanks N1GTR i hadnt read your reply before i wrote this PLea? u caring Bear you :ermm:
Looking into the same problem at the moment for a guys GTS-4. I will tell you what i find in the way of after market suppliers...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
