ECR-33
Its blue/silver 2 tone, cause thats my beasht. And my mate jason/ bugandy and i done that burnout at shagaz.
LOL did you guys get harrassed by the cops as well?
He would of been a old cop? (Greyiesh hair?) his names peter.
For the last 3 weekends i have told him there have been skyline cruzes through geelong, and one of the meeting points is the maccas!!! He is a nice bloke, he tryed dragging at a set of lights once in town! :burnout:
And i see a fair bit of this RRRR 33 guy, i heard he spent like 6K on the motor and stuff?? is he on the forums?
U GO GET FICKED ALLRITE.....
mate the pier street days went offfffff all rite offffffffffffff
oii
i dumped exhaust and ran full boosttt
ppoowwarr no traction reeee in 3rd gear when i flat stick boost kicked and i sliddeee outt...
dont wpryr wen i get VL i teach u!! haha
if i get it haha
im thinking i mite do what ur doin!!!
Trust me man,
After we setup, with these turbos. good for a 10 sec pass. Man if you get a VL you will regret it. I love VLs too man, but really if you weigh everything up man, handleing, interior, transmissions, running gear, LLOOKKS.
Man you wont be getting any prreemm little wog luttas in a VL. Only little hairy lebos. :shake:
Keep the 33~!!!!:D
hahhaa
pleeasseee they like me for me not my skyline hahahaha
hahahahaha
hahaha
man got heaps of lil whore for ya when u come down
locally
me and palo been susin out
all lil premmmm premmmm 17 year olds hahahahahahah
come down one week end man. and we gotta come up as well... sus out ur poofy poof area haha..
yeah move to the western suburbs??? i used to live in northen suburbs bundoora to be exact! lets see insurance ohh lots??? chance of car being BORROWED or just broken in too VERY VERY high! AND the VL's youd think they where as common as vx ss's and there are shit loads of them getting around! i admit melbourne atmosphere is the greatest (not many blonde surfie chicks but there is enough talent to go around)
i admit i have a soft spot for VL turbos but mainly cause if you look at them those 3litre engines are just skyline motors anyway.
i love my skyline and would never by a VL over it!
Originally posted by Zdenko
lol.... not u., just poofs that move from da western suberbs bronks to geelong like mr JNR24.....
that youg lade once use to hammer around with no exhaust threw willy altona with out a a issue
now his turned gay and  moved
Now i hammer through geelong with no exhaust!
Zdenko, i miss the good old days! once i get everything back on the car i will come down there for like a week!
And all we will do is do wog laps through altona & willi, go VL munching. SHHHIIICKKKKk. Then after all of that we will do some syncronized burnouts down the esplanade! :shake:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
