does this also apply for stuck on badge emblems? I have the chrome SKYLINE lettering stuck to my stock rear bar and want to get them off to put them on my new nismo rear bar as Its already got the engraving on it. Do I just heat up the glue and then it will be easier to take off?
https://www.sau.com.au/forums/topic/130153-vinyl-removal/#findComment-2407458
Yep, that'll do the trick. Heat it up alot, just careful you don't heat up the plastic too much or the paint. Slow and steady's the way to go. Take your time.
I used a hair dryer to debadge my car and the g/f's car. Then I used a bit of metho on a rag to remove any left over bits and pieces of sticky gunk (rinsed off with water after ofcourse).
https://www.sau.com.au/forums/topic/130153-vinyl-removal/#findComment-2408123
If its just the glue you want to take off then Jeff used his buffer and got rid of his GTS25-T sticker on the back of his 33.
Not too sur about vinyl but hair dryer sounds like a great idea.
https://www.sau.com.au/forums/topic/130153-vinyl-removal/#findComment-2408142
Hey c'towners,
Does anybody know the best way to remove vinyls from car bodies???
Please pm me if you know how, as i want mine removed, its annoying me
All of the above works but if you have any residue left on the car or you find the vinyl stickers are old and are coming of in very annoying little pieces then go to your local panel beater/spray painter (someone you trust) and ask them if they have a "caramel wheel" - it's a rubber drill attachment and smells like caramel but gets your vinyl stickers off really quick and safely! I have a friend who's a spray painter and he removed mine and you can't see where the stickers were at all..... good luck! :rolleyes:
https://www.sau.com.au/forums/topic/130153-vinyl-removal/#findComment-2412456
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
