Will it fit?
Need stanard suspension fitted to car to licence - cant find any stock 34 GTR suspension to borrow - but have got some gtt available - want to know if it will work?
I'm suspecting no.
Daniel
https://www.sau.com.au/forums/topic/130178-34-gtt-suspension-into-a-34-gtr/
r34 gtt and r34 gtr and r33 gtr suspension are interchangeable
tho the front suspension of the gtr are a bit shorter than the gtt's
i have r34 gtr teins in my gtt (well im pretty sure coz thats what the guy had them off)
the front is max height and it still looks lowered
pic attached
Edited by ecl
So is that a definative YES?
pic attached
Will it FIT, yes.
Is it suitable, NO.
But you won't be driving it much, so it doesn't matter.
R33GTR standard suspension would be better.
:rofl: cheers :P
Edited by Sydneykid
is it coil overs. if it isnt. just go over them with a presure pack black :O
spray it black,send it back ftw..
R34 GTR shocks are silver :)
Anyway I will have a set of standard suspension available soon after my new stuff arrives from Japan. Let me know if you solve your problem in the meantime.
R34 GTT suspension may fit but technically it's not standard so if they let you get away with that and comply it they may as well let you get away with any random suspension in it.
Well I got some GTt suspension - will try and put it in tomorrow - I will let you know how I go.
One more question - how do I take the back struts out - through boot or take back seat out?
Thanks again guys
Daniel
Thanks again guys
Daniel
Back seat and rear parcel shelf out.
:) cheers :)
Well just to clarify - it does fit.
Back sits alittle low(but still acceptable).
Front is bloody high - just like stock - looks ackward.
Drives like shit - but is fine for a short distance.
Car is now licenced .
Thanks to all for your help.
Daniel
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
