"It is safe to say your body kit is the least of your problems because I know for a fact everyone here would chip in the 25% restocking fee if you could share some hot pictures of your furry arm. This is some Ripley's Believe It or Not shiz right here...but for real, if you live in the Washington DC area, I will meet you in person, give you 25% of whatever that green plastic cost if I can just meet you.. shake your hand, touch your fur, whatever.
-dmc7173"
that is the funniest reply ive read in a while...
https://www.sau.com.au/forums/topic/130181-sasquatch/#findComment-2408269
    • I also built one, for a bit of a laugh. Pretty happy with it. Basically, obtained a clear garnish, painted it sanded back the paint off the letters, clear coated it. Inserted a 3cm EL strip through a slot I created in one end and sealed it up.
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
