R32 GTST MANUAL 92mdl 2door
80,000kms
burgandy in colour
coil over shocks lowered
alarm cental locking & remote start
turbo timer
3'' exhaust
tinted windows
kenwood head deck, 6*9s,12"sub and sony 4channel amp
sports steering wheel
new extreme H/D clutch, and new slave and master cyclinder
interia in immaculate condition
has servise history
new front and rear brakes
new tyres
just had a major service, injectors cleaned and inlet manifold gaskets replaced.
car is in excellent condition inside and out.would have to be one of the cleanist around. has 12months reg a can organise a rwc.
Located in melb, northern subs
GENUINE ENQUIRES ONLY PRICE DROPT TO $10,500
CALL LUKE ON 0411-117-801
Edited by rbfrog
https://www.sau.com.au/forums/topic/130255-r32-gtst-4sale-melb-cheap-pics-pics/
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
im am currently in market for r32s and i am very interested. i am located in perth but may be able to buy from eastern states if i can find cheep transport. what is the best time to contact you about details on yourcar.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
