R32 GTST MANUAL 92mdl 2door
80,000kms
burgandy in colour
coil over shocks lowered
alarm cental locking & remote start
turbo timer
3'' exhaust
tinted windows
kenwood head deck, 6*9s,12"sub and sony 4channel amp
sports steering wheel
new extreme H/D clutch, and new slave and master cyclinder
interia in immaculate condition
has servise history
new front and rear brakes
new tyres
just had a major service, injectors cleaned and inlet manifold gaskets replaced.
car is in excellent condition inside and out.would have to be one of the cleanist around. has 12months reg a can organise a rwc.
Located in melb, northern subs
GENUINE ENQUIRES ONLY PRICE DROPT TO $10,500
CALL LUKE ON 0411-117-801
Edited by rbfrog
https://www.sau.com.au/forums/topic/130255-r32-gtst-4sale-melb-cheap-pics-pics/
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
im am currently in market for r32s and i am very interested. i am located in perth but may be able to buy from eastern states if i can find cheep transport. what is the best time to contact you about details on yourcar.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
