Gb: Brand New Z32 Afm's - $330.00 Each
Hi guys, while looking around for some new Air Flow Meters for my GTR, I have found a great deal for brand new Z32 AFM's which sees these new AFM's priced only a touch higher than what you would expect to pay for a used item.
Just Jap in Sydney has kindly offered to supply the AFM's for this group buy for $330.00 Each (Inc GST)
Tomei Z32 adapter plugs will be available as an optional extra for $49.00 each.
Important Information:
* These are genuine Bosch Z32 Air Flow Meters
* Each AFM includes a 12 month warranty
* We require 10 or more buyers for this group buy to proceed
* Express delivery is available for $10.00 Australia-wide
* The closing date for this offer is firm
Once we have 10 people confirmed on the list, the order will be placed and you will then be asked to make your payment.
Pickup will be available from Just Jap in Kirrawee, Sydney (South), when the group buy concludes, otherwise express delivery is available
Note: I have already confirmed stock availability with Just Jap
Group Buy Start Date: 15/8/2006
Group Buy End Date: 15/9/2006
Making your payment
Payments will be accepted only via direct deposit - Instructions for payment will be supplied at a later stage.
What are you waiting for? Register your interest NOW :)
BUYERS CONFIRMED:
Blitz 2 x AFM + 2 x Tomei AFM Plug PAID & CONFIRMED & POSTED
d00dz 1 x AFM PAID & CONFIRMED & POSTED
Danoz 2 x AFM + 2 x Tomei AFM Plug PAID
rbsilvia 1 x AFM + 1 x Tomei AFM Plug
FLYSLY 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
Crack 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
AcoustiK 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
_8OO5TED_ 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
pulp 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
2face 1 x AFM + 1 x Tomei AFM Plug
al_r33 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
steves180 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
babia 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
writeoff 2 x AFM
jetdat 1 x AFM & 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
darkl0n 1 x AFM & 1 x Tomei AFM Plug PAID
R334Door 1 x AFM PAID
https://www.sau.com.au/forums/topic/130308-gb-brand-new-z32-afms-33000-each/
  • Replies 117
Registering interest.
Can I pickup?
Now to find plugs for this hmmm
Vic, no need to find plugs, they can also supply the Tomei Z32 plug adapters, will append the first post shortly with details.
Also as above, pickup will be available at the conclusion of this group buy
How do i know if i need the adapter?
If you are fitting this to a Silvia, GTS-T, GTR etc, you will need the adapter plug as your factory AFM plug will not fit onto the Z32 AFM.
Ok how soon can i pay for this and have it delivered?
Looking to get one ASAP
They are ready to go, however we need 10 people confirmed to secure this price of $330.
Would you like me to mark you down as confirmed?
Yes im definately in, works out cheaper than nengun which is awesome
Thanks mate, I have added you to the list.
Will you be wanting the AFM adapter as well?
Yeh sorry mate.. im eager thats all
Its a bargain and an AFM is something that a lot of people would be due to buy so we should fill up the 10 easily and fairly quickly i'd imagine...
Not very often things go cheaper here than from greenline or nengun.
Hopefully it will arrive faster too I dont want to have to wait 2 weeks...
Thanks for organising this - great group buy
Happy to help mate.
Once we reach the minimum order (10), and your payment is processed they will be ready for pickup and dispatch straight away - A quantity of them is already set aside for this group buy :)
I will advise more details soon.
Nick
Keen on one with adapter, but a couple of q's
Would I need a tuner to hook up the plug, or can it be just adapted to the existing plug? Also, do I need to retune my ECU?
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
