Gb: Brand New Z32 Afm's - $330.00 Each
  • Replies 117
Blitz, this may seem like a sil question, but is there any difference between the genuine Bosch item and a Nismo one?
The Bosch/Nissan Z32 AFM's are 80mm,where the Nismo/Tomei units are smaller in physical size, but still have increased voltage capabilities over the standard AFM - They are also significantly more expensive and tuners I have spoken to seem to prefer the standard type 80mm Z32 over the Nismo/Tomei type units.
Hope this helps
Payment made and email sent to Darron
Alan
Hi Alan, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581246)
Cheers,
Nick
Received the AFM yesterday, damn quick delivery :ninja: Thanks mate.
Anyways anybody know the wire colour codes for a R34GTT e.g which ones signal, batt etc, gonna splice and hook up myself...
Your very welcome mate :ninja:
Payment made and email sent to Darron :ninja:
Gday Matt, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581247)
Cheers,
Nick
CAn you hook these units up to a stock RB20DET and see a difference or will it be just a waste of time until i get my Power FC?
Thanks guys
You will need to wait until you have a Power FC :D
Woohoo! Received mine today! thanks mate! :D
Also does it matter if on one side of the mesh it's slightly dented? doesn't look too bad might be able to gently move it back in place.
Cheers again!
Received the AFM yesterday, damn quick delivery :D Thanks mate.
Hey AcoustiK, try this thread, might help you a bit! :yes:
http://www.skylinesaustralia.com/forums/in...howtopic=116520
Woohoo! Received mine today! thanks mate! ;)
Cheers again!
Hi Dave, glad to hear it arrived safely - The dent in the mesh wont be a problem, in some cases people remove the mesh all together.
Hey Blitz,
Just transfered the funds, and emailed Darron too.
Thanks
Hi Nikki, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581250)
Cheers,
Nick
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
