Well might as well give this a stab.
Since everyone knows the government and its plan for LPG in cars.
Does anyone know places in Sydney to have their car installed with LPG?
And if so prices would be good. Mates rates would be good too >_<
Prices have probably doubled since the government's announcement. :)
Been thinking about this for the Corolla.
What are everyone's ideas?
Thanks
https://www.sau.com.au/forums/topic/130319-lpg-installers-thoughts/
one of the guys here just got an LPG conversion for a v6 commonwhore. I think it was $4k or something.
What I can't get over is the fact that the LPG technology they convert your car to use was designed back in the 60's.
LPG systems are a joke. why you want to convert a decent EFI car to one with a half arsed carby set-up is beyond me. just to "maybe" save a few bucks and spend your time driving around in a backfiring, hard to start car that smells like fart.
big thumbs up!
at least then your lame trdy plate might make a little sense as every time you drive past someone with think the person walking in front of them just filled his nappy.
haha, man i am cruel.
2k of fuel prolly lasts a long time...
hmm
actually, with petrol prices these days and the inevitable increase predicted with the coming months and if you fill up for $80 a tank (bp ultimate) a week it would take roughly 20 weeks to spend that money. that's less than 6 months.
my question though is will converting to lpg decrease a car's performance? ie. skylines in particular (apart from the increased weight of the tank)??
The general rule of thumb is that you lose around 5% power going from petrol to LPG. Not sure if its the same for turbo cars, since most people who do it tend to run NA engines.
If it burns cooler at a higher octane, you can always offset this by running more boost.
Saw an article in some HPI or Zoom mag. I only briefly read it though and can't remember exactly what it said.
But the gist of it went:
There's a workshop in Queensland that's actually developing a proper LPG system.
The owner of the shop has converted his BA xr6 turbo to run on petrol and LPG but with proper injection and engine management (different to the normal, "lets blow lpg down the f**king intake pipe and take a brand new engine and make it run like it was designed in the 60's").
After tuning the car apparently makes more torque down low, and switches to petrol seemlessly up high in the rev range to give better top end, or something.
Freaky. I remember putting gas a couple of old v8's I owned. The peak torque area moved UP about 1000 revs.
Also I don't think unleaded takes you 30% further, LPG is something like 8-10% less efficient without making other changes to the engine, eg ecu and cams.
I thought it actally burned hotter than petrol which was why one of the age old drawbacks of it was burnt out valves, particularly on engines designed to run on leaded fuel without hardened valve seats.
There was a guy on the forums a while ago building up an engine in his line which he was going to run on dedicated LPG. He said they were looking at 10-15% increase in power due to higher octane rating of gas. Sounded like he had done his research, but i dont' know a whole lot about it except that i've seen it on dual fuel systems and it runs like a dog.
However i would be interested if they proved it would run nicely, and save a bit of money (considering LPG is almost 1/3 the price of petrol now)
$80 tank x 20 weeks = $1600
apologies for not being clear with the calculation. the reason i estimated this price is because the money it will cost to fill up a tank will increase over the next 6 months.
anyways, i agree with what shif-tea..
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
