Hi All
Been reading up about the stagea the last few days, seems like quite a good car. I own a fwd coupe at the moment. I have the choice of spending a few thousand on this car, ie mags suspension etc.
Or save up for the Stagea. I just have a few questions. I'm currently looking at a series 2 manual.
I have heard the manual Series 2 stagea is better on fuel consumption than the series 1 auto, is this really the case. Is the series 2 much better on fuel than the series one.? Was wondering what figures series 2 owners were getting. I know if you can't pay for the fuel don't buy the car, still would like to know.
How are these cars reliability wise?
Anyway back to browsing :mad:
edit: i'm in canberra btw
Edited by CeJay
https://www.sau.com.au/forums/topic/130324-another-stagea-noobie-here/
hi mate, welcome!! the S2 is better on fuel... as i have an S1 i couldnt honestly tell you what kind of consumption you would expect ...but something to condsider is if you plan on modifying it then thats gonna change everything anyway ..and S1 with some good mods = similar price as S2 stock
Just my 2 cents
oh n whats the coupe you have and what mods where you thinkin of doing to it?
Lee
mazda mx6 2.5ltr v6. Was going to lower it put on 17's then perhaps put in a j-spec engine. But that's starting to get exxy considering its fwd, and performance isn't exactly crash hot.
Thats why I'm considering my options atm.
Well in our case...Bretts S2 is crap on fuel compared to my S1...i filled up before the sauwa car cruise and just filled up and i got 478kms to the tank from full to empty light on! I did give it some on the car cruise and have pushed it a little hard over some days but normally I never get to 100ks unless i go the freeway which is rarely so i normally have city driving of about 80ks most..with a shit load of stop starting!!
Just my 2cents but i think every stag is different :D
How bigga lode o shit do u use /100? :rolleyes:
generally in the vacinity of 20L/100Km
if i can get a bit of freeway driving into it, i hav had as good as 14L/100Km
powerFC is the answer...come on i want another S2 manual guinea pig to compare things with.
ive got the power fc sitting at home, just gotta get around to fitting it/sorting out whatever issues it may have.
as soon as its in i'll book some dyno time with UAS and get it tuned
thx for the responses. How rare is a manual Stagea anyway? How many k's do most of you guys have on your cars?
Bit worried about the high mileage on the one im interested in.
Edited by CeJay
i'm about to hit 180,000km, and also about to change to manual. car still goes fine, maybe head gasket should be replaced at 200,000 but nothing is leading me to believe anything is physically wrong with the engine. i've upgraded most parts i can without affecting the engine so that might have helped. i think the RB series are a strong engine.
Mine has just hit 121050km...i have done 1000ks since having her :O and i still get excited everytime i get into her :O
The ungentlemen on this forum could seriously misconstrue what you have just said. :)
nah nah its true :P i get really horny when i get in my stag :rofl::O now boys get your minds out of that gutter :O
On a serious note! Well. The general consensus, not just here, but global, is that Nissans NEVER break, they just wear out. After about 5 or6 hundred Ks.
Total FW drivers break Nissans.
FAAAAAAAARK. My S13 has comehome and I HAVE to get OFF my computer .
See you lateeeeeeeeeeeerrrrrrrrrrrrrrrrrrr.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
