hey people after sum help if available... i cant seem to lock my driver door (r33) via key or alarm ... i had purchased one of those viper alarms systems that were floating round a while back and have never had a problem.. and not sure if its the viper that has done it ... or just the install job was dodgy maybe and over a matter of time sumthing has gone loose or fallen out (in the door) ... had it installed at autobarn .. n yeh. any suggestions? cheers - JT
[ alarm still goes off if door is opened obviously, but door wont lock! ]
https://www.sau.com.au/forums/topic/130325-door-wont-lock/
Shouldn't be too hard to take the door trim off and check that the actuator power wires are still attached.
I would have thought that you could physically lock the door with the key though! Might be worth checking that it hasn't let go of the rods or that the rods aren't stuck on something?
https://www.sau.com.au/forums/topic/130325-door-wont-lock/#findComment-2411901
