you would need to use a timing light and adjust for as close to 15 deg BTDC..
if you dont have a timing light, try to get it lined up so that the bolts are in the centre of the sliding opening on teh CAS.. then drive it to a mechanics that can adjust the base timing ..
put it there incase you have too much base timing, you dont want it pinging
