Hi Ppl
I got a series 2 r33.
So far, i have got just a BOV and Intercooler Hybrid.
I recently bought Venom 800cc injectors, a fuel regulator and im getting a bosch 044 fuel pump and there installing tomorrow, would they run good without a computer. and also changing timing belt but thats not important.
im going to purchase an Apexi FC, just as soon as i get the money.
After the apexi Fc, im getting a bigger turbo, what would be the best and biggest turbo i could get running these mods, and what other mods do i need.
https://www.sau.com.au/forums/topic/130371-some-help/
Guest 40th-edition
The fuel stuff will run good with standard computer but better with Apexi FC... the standard comp will take a wile to figger out whats going on and then probs slowly tune it back to specs so FC will help with that!!
dont know about turbos but depending on how far u want to go..
-exhaust system
-intake manifold
-cams & adjustable cam gears
-pullys
depends how far u want to go! and spend!!
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2412294
-exhaust system
-intake manifold
-pullys
Well i am gonna get the exhaust connection from the turbo with that cat thinggy (not too sure, i have have it now from half way, im going to connect from turbo soon $600)
I will be getting a newer manifold for the turbo, i heard using the standard manifold, you wont be able to get a big enough turbo, and the rest, i havnt heard off cams and pully, without making fun of me, what are they and what are they used for.
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2412317
Guest 40th-edition
thats cool man...
good idea to get a decent dump pipe off your turbo (u could get one to suit new turbo)
cam shafts r what makes your valves go up and down.. and i can buy diffrent ones with diffrent off set degrease to extend the exhaust and intake opening for..
and you can buy lightened pullys to run your belts on... only worry about that when u have serious power...
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2412366
You can fit a plenty well flowing turbo on the stock manifold.
Dude, you need to set:
A power goal
A budget
A current list of mods
1) I dont think 800cc injectors is worthwhile, its overkill and will affect economy adversly
2) A fuel reg - not required
3) Engine Management - 100% required if you are going to use larger injectors. It wont run with 800cc's on a stock ECU, or anything other than factory.
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2412370
A power goal
A budget
1. Power goal, i want 11-12 sec
2. a budget is at the moment $5500
3. 800cc venom injectors
fuel reg
fuel pump bosch 044
hybrid intercooler
gfb bov
exhaust from half way
turbo timer
apart from a kick ass entertainment unit, thats all the mods.
I was given a quote $3000 for T3/T4 turbo, manifold, dump pipe and fitting.
and about $1500 for apexi fc installed
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2412409
You need a full exhaust, not just a cat back.
I would send your turbo to GCG for hi-flowing.
www.gcg.com.au
Sell the fuel reg/Injectors
Purchase more realistic sized injectors... Nismo 555/550cc, PowerFC, Z32 AFM.
You'll also need a clutch $1000-$1200
That will top out for $5500 easily, and you'll have around 250rwkw
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2413432
firstly, if the timing belt is getting done make sure you do the bearings in there along with the seals and maybe even do the water pump. Also check the welsch plug behind the water pump as its a nightmare to replace later on.
Secondly, if a workshop is fitting up all these fuel system upgrades for you I would find another workshop. They should know and should of informed you that it wont work. They either dont have a clue or see you as an easy target.
Backyard billy would know that fitting the fuel system components you have on the stock ecu will result in an undriveable car. It will have fouled plugs and be blowing plumes of smoke before you get out there driveway.
https://www.sau.com.au/forums/topic/130371-some-help/#findComment-2415764
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
