Anyone Got Anything Done By Rotech Or Fueltech?
Beef
 Share
Hey lads, im looking at getting my new boost controller installed and tuned by ROTECH in Devonport...
anyone ever had these guys do anything to their car?
what are they like? reliable? dodgy?
If not who is a good tuner that i can go to to install and tune my new boost controller...?
im puting it on an R33 gtst? does anyone sort of specialise in them?
anyone know of a good tuner in launny?
Im thinking Chris Colgrave or Fueltech... how about these guys?
Beef
Edited by Beef
what sort of boost controler is it? do you know anyone that could put it in (like back yarder) i have instaled mine myself althoe i didnt realy tune it myself but they arent that hard just pretty time consuming.
any of the places you have listed will charge like $70 per hour at least so it will cost a bit to get it put in. but if you like drive in drive away service than get someone to do it. if you like a bit of hands on im sure somone (or myself) may be able to lend a hand, if you want to go down this road search the how to forums as they will tell you were and what wires and vac lines to tap into.
hope that helps
hope that helps
cheers man, yeah well it already has the sources becuase it currently has a boost controller, im mainly after somone to tune it... and take teh blame if something goes wrong.. LOL thast all... i can hook it up myself in about 5 mins i know how they work....
Beef
Rotech are rotary guys arnt they?
yeah rotech do rotarys but they also do lots of other mods too especially on r32's ive heard...
apparently they are quite good and laurie (the boss) is a bit of a guru...
thats ok i wasnt sure what you did/ didnt know. im pretty hesident to toutch other peoples cars out side of work because if the slightest thing goes wrong... well you know
yeah thast true man, i prefer other people who are insured against that sort of thing to do it, becuase if they stuff it up you can recover costs.
if you do it urself and stuff it up... well your up shit creek
Beef
I get fueltech to do all my work, pete will sort you out....tell him Taz sent you....I have the yellow R33 in there at the moment!
cheers man, so if i say hey.... taz sent me and said you would look after me... he will know you and will actually hook me up?
Beef
just say I sent you his way . you should get looked after hopfully!
a boost controller shouldn't cost much more than $100 or so to fit and tune.
i rang him today man...
$50 all done and dusted.... ready to go..
:O Beef
Edited by Beef
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
