Trust Power Extreme 2 Catback Exhaust On R32's?
Seems a reasonable price, some other things to consider, driveshaft & xmember, you'll need to run the speedo off the abs, an after market lever/bracket. You'll most likely want to change the diff ratio, do you need any kind of certification in the uk for it? If the car is quite low, the cd will hang down lower than the 25 box.
He said in the OP Wollongong area.
OK, well, being realistic: RB25DET gearbox (new, from Nissan), A$4k. Good clutch, >A$1k, possibly $2k. So, you're already into the ballpark just with those two things and to stay 5 speed. Someone has borne costs and done work to put the RB bellhousing on the CD009, and there's some other parts included. It seems like a reasonable price to me. It's not as if these things are lying around where you can just pick one up (the whole kit, readyish to go) and/or play off one vendor against another. So the pricing has to seem reasonable to both you and the seller.
I did At the top of the page ? Is it not showing - I’m looking for $800 ONO
But you can stand next to your strut brace with the bonnet up in the Bunnings car park and people can see it. Can't see dampers.
