*Fibreglass R32 GTR Rear Wing - $80
*Bridgestone Potenza Shocks (stock length, front and rear) suit R32 GTS-t - $150 for all 4
*Standard R32 GTS-t Front and Rear Swaybars - $10 each
*Standard 2 1/2" Cat - $10
*Standard R32 GTS-t Dump & Front Pipe - $20
*Standard R32 GTS-t Rims x 4 - $250/set - Tyres No Longer Available
*Standard R33 GTS-T/S14 Rims x 4 - $250/set - Tyres No Longer Available
*Standard R32 GTS-t Turbo - blown - would make good turbo for highflow - $80
*Standard R33 GTS-T Turbo - No Shaft Play, Appears to be GREAT condition, just makes a whining noise all the time (i.e. does it even when not on boost) - $200 - SOLD
*Standard R32 GTS-t Front Brake Rotors, good condition - $100
*Standard R32 GTS-t Intercooler - $40
Non Skyline Related Parts:
Autometer Water Temperature Gauge - Never used - $150
AE82 4AGE Inlet manifold - $50
AE86 diff housing (no centre) - $20
AE86 rear drum brakes - $Free with Diff Housing
Holden 202 Inlet manifold - $20
Holden 202 Varijet Carby - $10
Blown Amp - $Free
Woodgrain Steering Wheel - $50
These parts are just off the top of my head, i quite possibly have other stuff laying around as well, which i will add as i find it!
I am open to offers
parts are located in Brisbane
Please contact me either on my mobile - 0402 202 978
or via PM
or via E-mail (jwgeh @ tpg.com.au)
Many Thanks
Jason
https://www.sau.com.au/forums/topic/130407-assorted-skyline-parts-others/
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
    • That awesome thanks for that.
    • You can Remote any of these VR30..globally  Check: AMS Performance | Racebox | Sonic Tune | Soho | Z Motorsports | Specialty Z    Performance Parts | AMS | Z Motorsports | Boosted 6 |    Exhaust | Fast Intentions | ARK | MBRP Motordyne | Borla    There is someone in Sydney with 650whp   I am at 430whp without flex fuel, but FBO & Flex-fuel will push you to 500whp!!
