Guys
A mate of mine recently rebuilt his rb26 on his gtr, and riped off the turbo's and paid a mint for a preety damn large one, in which they removed the manifold, turbos etc for the single new one.
I got a gts-t and was wondering if its possible to use his manifold and turbos and put em on my gts-t.
Has this been done before, or is it possible at all??
cheers
https://www.sau.com.au/forums/topic/130414-rb25-with-rb26-manifold-and-turbos/
Its been done
You need to have adapter plates created. End of the day, dont do it.
When the ceramic turbo sh|ts itself... your more than likely going to break a motor :D
stick with the single turbo idea. Less hassle.
Was that $3k including the turbos and manifolds or just for the manifolds and adaptors?
If it's $3k for a twin turbo setup then why not :huh: Not saying I'll do it; but surely there must be benefits in having two turbos over one.
you can get the adoptor plates from japan.
the same people that make the kit for the 26 plenum onto the 25, make the gtr mainfold adoptor plates pretty cheap too..
i wonder how i set of steel wheel r34 n1 would go on a 25.
if i had the money and time i would give it a shot just for the fun of it :huh:
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
