Hi guys,
I've just bought a r33 series 2 turbo, stock apart from pod, and 3 inch exhaust (mandrel bent) turbo back and hi flow cat. I'm putting on a turbotech boost contoller. I am sure this has been asked 1000 times before, but what is a safe level of boost to run (engine has done 55000km - thought to be close to genuine).
Any help much appreciated
Cheers
Jeremy
https://www.sau.com.au/forums/topic/130450-safe-boost-level/
Jpowys 10psi is about the max id recomend but it is debatable some have run 14psi for long periods and some have let go at 10psi or less. with a stock intercooler on a hot day you may run into problems. Have a look at the r33 tuning guide on my site it provides good info and saves you searching all over the place.
cheers
obviously depends on the age etc..
up to 10-11 is cool, But should be fine for up to 12-14, but would recommend replacing it anyway though!
best to be safe than sorry!
some people go for second hand gtr's, dont go for that, just get a walbro or bosch, think they go for 040 and 044, also known as bosch motorsport pump
Nothing wrong with a GTR pump....Much more reliable than the Walbro's.
Evil Wvl = If the standard GTST fuel pump performed to specs then it is suitable for around 225RWKW. Unfortunately, this is hardly every the case.
fuel pump....when would this start to not flow enough and with what mods?
and what do people replace their stock fuel pumps with?
(sorry to hi'jack thread)
I've about to install a fuel pump from a 300ZX twin turbo. Suitable for up to 260RWKW.
thanks for the replies guys. What is a upgraded fuel pump worth? Sorry GTR_legend, i was not sure what you meant by "040 and 044"... Do you mean $40 or $44 dollars? Also, once i have installed the BC and established what seems to be a safe boost level, is there anything else I need to do?
Edited by Jpowys
040 and 044 are models of Bosh Fuel pumps.
Need to do? Start saving coz once you've got the mod bug it never stops. :)
i have read that with stock intercooler 10psi would be sufficient for daily driving - but dont take my word for it.
Im planning to put an aftermarket intercooler next year, and bumping up the turbo to 10psi - I believe any more than 10psi and the ecu will go crazy.....
By go crazy you mean r&r? The ECU will only hit r&r when it detects excessive levels of knock/pinging. Some guys hit it at 9Psi. Some guys wont hit it till 13Psi. Some guys hit it earlier than others coz they use shitty fuels or have crappy injectors. So many more variables other then just simply upping the boost. The ECU does not ready how much boost you run.
R&R isn't caused by pinging or knocking, your motor will still ping and knock if its got normal unleaded petrol and no R&R kicks in to stop it, its caused by excessive air flow, in a series2 the max boost the stock ecu likes is 10psi, any higher and R&R kicks in, i know cause i have a S2.
When the stock ecu gets the reading from the AFM when boost is over 10psi it thinks something is wrong and starts the R&R as a safety net as not to stuff your motor. On S1's i think its about 12psi. But in saying all that i have also read that some people were able to get more from stock ecu's in S2's. I also thought the stock turbo runs out of huff past 12psi, anything over this and it just blows hot air. Plus you have to be careful that it doesn't throw the ceramic exhaust wheel out as this is the weak link in the turbo when boosted past 10-12psi.
Ohh and by the way, i don't think you did use the search button, this has been dicussed many times before.
this is what i think is safe you just got your car right, get use to the power it already has for a few months, you'll probably be trashing it everyday in the first 3 months, so its safe to run stock boost, (hint, with 10psi and trashing it everyday, bye bye turbo)
then get your turbotech, pur it on 10Psi you could try 12Psi on really cold nights just to c how it feels, run your 10 Psi all the time but to trash it in hot days, when you get a front mount you can trash it abit harder,
or maybe get that flick switch thing boostcontroller set it to 11Psi and stock, 11 cause you'nt be runing it all the time... get me...
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
