Hi guys, for some reason i can't use the search section, no idea why.
Anyway, i just got a 95 series 1.5 R33, and i was wondering if on the driver side seat, does it calopse and come farward so people can get in the back, same as the passanger side. I have the lever and the seat calapses, but does not come farward, just need to know.
Thanks
https://www.sau.com.au/forums/topic/130452-r33-driver-seat-question/
not automatically. You have to use the "under seat level to pull it forward. I prefer it that way coz it's one thing less you have to adjust after mongs get out of your car. Send them to the other side.
yeh only the passenger seat slides forward automatically.
Anyone know about the GTR seats?? Recently upgraded to R32 GTR seats and the passenger seat doesnt come forward automatically. Just behaves the same was as the drivers side.
Is the seat stuffed or is that normal?
