Where do you guys think i should go to get my safc II installed and tuned, as well as some other fine tuning? At CRD or hitman?
CRD is closer for me, however, when it comes to safc's i have heard hitman is the way to go. So, i am just seeking some of your combined wisdom here guys...
i have heard great stories about both and obviously their rep is fantastic, so i will have no problems giving either one my business...
https://www.sau.com.au/forums/topic/130463-crd-or-hitman/
i say get he best of both worlds and go to CRDMAN. or HITRD.
seriously, all this thread is going to give you is 10 guys posting saying "I went to hitman and it was great" and then 10 more saying "I went to CRD and they were great".
you could save all the hassle and just do a little search in NSW section, or just ring them both, get a quote, get a feel for them and then pick one.
https://www.sau.com.au/forums/topic/130463-crd-or-hitman/#findComment-2414588
can i ask why not get full management?
i always wonder why when i read a thread like this about getting an expensive professional tune for a halfway decent result
i can understand wanting to spend the dosh on someone like CRD or hitman if you were going with a PFC or silmilar but i put little weight on just how expensive and overboardf a tune should be for a safc
this is not an attack on you or anyone else with a safc just trying to understand
https://www.sau.com.au/forums/topic/130463-crd-or-hitman/#findComment-2415129
automatic transmission jimbo, otherwise it would have been pfc. afr's are very rich so i thought why not fix that with the tax return money
beer baron, now the reason why i put a thread about this on here is because maybe someone, or knows of someone, that had a problem when tuning (even though it would be unlikely as these workshops are of high quality)
so better check all my bases first, just in case...
Edited by Fly_With_Sky
https://www.sau.com.au/forums/topic/130463-crd-or-hitman/#findComment-2415175
just getting some opinions on here as well...isn't that one resaon why these forums exist?
yeah true. it is one of the reasons the forums exist. It's just that we get one of these threads every month or so, so the most recent one would hardly be out of date, and the opinions will just be a representation of people on the forum. same as this one.
https://www.sau.com.au/forums/topic/130463-crd-or-hitman/#findComment-2415176
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
