So who won? NSW?
Ive spoken to one of the head Vic guys and he agreed NSW had it
But he was drunk (arent they all :wave: ) so that debate will start when they all get back to their computers
Dave was pretty funny with his ECU having a bad hair day and dying, then still managing to do some of the fastest laps of the day (there was an open wheeler class). He even pushed a few of them off the track, not literally, he was right behind a few of them at different times throughout the day and the pressure of a welshman must've been all too much resulting in a few people in the dirt :)
  • Replies 418
Posted Images
Dave was pretty funny with his ECU having a bad hair day and dying, then still managing to do some of the fastest laps of the day (there was an open wheeler class). He even pushed a few of them off the track, not literally, he was right behind a few of them at different times throughout the day and the pressure of a welshman must've been all too much resulting in a few people in the dirt :no:
Alcoholics!!! The lot of ya! :huh:
Sucks I wasnt there. :( Stupid work..
Who spun out the most? :)
Alcoholics!!! The lot of ya! :)
Sucks I wasnt there. :no: Stupid work..
Who spun out the most? :wave:
Dont start on the booze, there was more than ample :(
Im not sure who spun the most, its normally you :huh:
this time around, I spun out the most.....5 times
the poor v35 shat itself on the track after a couple of lap, what a way to spend $90
after spending the day being raped by GTRs around corners and straights, I am definitely impressed with the way these things go around corners, the speed out of these corners is unreal.
So Chris (white 33 gtr) was the fastest from vic? his car is nearly stock guys :D and you needed a t04z to keep up ? :rofl: wait till you see GTREAL (silver 33) and aarons white 34 at EC.
(gotta start the kb warrior stuff since i can't be there) :)
You do know the V35's oil patch on the braking point on the back straight caused major dramas?
I came off hard there and scratched a rim, the WRX went into the Marshalls booth, the Clio almost hit the wall and the MX-5 and EVO slid into pitt lane!!!
All in a row, like dominos!!!
My GT-R still isn't sorted, so laggy but was doing 1.11's.
there were SO MANY tough GTRs there, it was just crazy. I remember being at wakefield a few month back for the Official track day, most of them were gtst but yesterday it was like the big boys coming out to play. They should've taken a photo of all the grey GTRs together, they were all doing around the 1.10-12s.
ONLY 5? Thats shamefull! nono.gif Shoulda done more.. :rofl:
hahhah hey i still needed to do some good laps too you know.....but the morning session I was spinning out every couple of laps from the cold track...and you should've all seen my half assed attempt at drifting and some countersteer and not having a clue wtf I was doing.
I have finally had enough of the fked up HICAS
the hicas is working as it should, it's just I don't like the feel of it anymore, it's unsettling, I couldn't tell if I was loosing traction or the Hicas kicking in, but I managed and it was fun nonetheless.........U SHOULD'VE ALL BEEN THERE, it was FUN FUN FUN!!!!!!!!!!!
That thing was pretty quick for an N/A but every time it went past it felt like my ear drum exploded i got a couple of pics up. have a few more at home
http://www.skylinesaustralia.com/forums/in...5932&st=200
did anyone get some photos of the ugly and stupidly loud black Silvia? :whistling:
Ferni, listen to the excuses fly. The std GTR has twin aftermarket turbos, ECU, bigger injectors. Very well sorted suspension, aftermarket rotors, and runs 18" semi slicks...i love how you VIc guys say thats std?????
Take it like the mice you are. NSW WIN @ Wakefield. If the R32 was there you would have seen it punch out a 1:08 :whistling:
The evo's would dominate the lines at Wakefield... When i was there 2 weeks ago a blue one was pulling 1.08's and the odd 1.07 all day :whistling: it was bloody quick
Take it like the mice you are. NSW WIN @ Wakefield. If the R32 was there you would have seen it punch out a 1:08 :rant:
Thats what they all say :rant:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
