  • Replies 418
Posted Images
is it ok if people who want to crack a 1:15 come along too??
seems like theres a few too many quick cars coming.
All is welcome
The day will be run in sessions so there wont be any issues :D
I'll be there lol.
and with the way things are going I'll be going around the track on foot
LOL...truth is thats probably about the times i will be doing, i dont really care. The way i see it all these quick cars get less track time. They do their 6 or so laps and beign 5 seconds quicker per lap means they actually get less track time....lol, those silly buggers :D:D
Better add SOSK (son of Sydneykid) to the list. I might let him drive the R32, or he can use his R33. That way if the R32 isn’t going, we can both use the R33. Always good to have a fall back situation. If it’s raining, I am going to use the Stagea though.
:P cheers :(
PS; Is this State of Origin? So Roy is on the NSW team.
:P cheers :(
SOSK added for you :O
:P cheers :(
Wow thats quite a fleet! I like it!
On a side note! I cant wait for this
:PBJ: (As the token Queenslander I thoght it was appropriate to use the bananna to show my excitement)
how do you know that duncan??? kel's not going to like this revelation.
troy is definately all nsw. he is far to good looking to have been born in melbourne.
Of course you're welcome mate!
We're used to your rotor
Staying the night before aswell?
Not sure yet about the overnight thing,,,I tend to drink way to much beer which always bites me on the arse the next morning. I need to have my head on straight as I need to get under 68's if I'm gonna play sports sedans next year.
By the way where are you thinking of staying?.
Add me to the list though,,,I've got the week off so Liz and I can talk race tactics.
Neil.
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
