hey another 33 from nz
bitta work done here and there - also with a few diff stages of engine progression :laugh:
post-35218-1170812582.jpgpost-35218-1170812616.jpgpost-35218-1170812664.jpgpost-35218-1170812713.jpgpost-35218-1170812768.jpgpost-3-1129700567.jpgpost-35218-1170812881.jpgpost-35218-1170812981.jpg
car was brought bout year and half ago - engine stock/on 17's and lowered. also all sounds replaced and still changing as i go :laugh:
Edited by mofo
  • 3 weeks later...
Hey guys, not sure if i have added my pics to this thread already, but heres some recent ones anyway.
Sorry about the big size
Tooo sexy.... That has got to be the hottest series 2 I've seen so far, EVER!
Nice job with matching things up, wheels, bar and side skirts!
but I have questions :D
- What size, brand & offset are those wheels?
- Which side skirts are those?
Thanks in advance!
Edited by Pax-Ottomanica
Beautiful car mate
Love it, the white letter tyres love it
Thanks guys :nyaanyaa:
Yeah...the white lettering I think looks cool. All it takes is about an hour of your time and some white paint pens :happy:
They look like Volk TE37's ...awesome looking rims :laugh:
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
