Everyone to their own, but I can't stand the series II front bar... looks hideous - otherwise, very clean car... should get it tinted though.
Cheers.
At least it isnt as bad as the series one front bar..
The series 2 needs the nismo lip to make it look nicer
like this :(
like this :D
haha I've had that lip sitting in my house since July, just needs to be fitted and painted... Lazy bastard. Have always loved the look of lip extension and gtr wing. Stock appearance but just adds a little more.
Update: Engine build is almost complete :banana:
Still alot of fabrication required, but should be ready in 2 weeks!!
For those that haven't seen my car or can't remember it, some old pics. These will be updated in a couple of months.
post-1811-1203670146_thumb.jpg post-1811-1203670225_thumb.jpg post-1811-1203670045_thumb.jpg
Update: Engine build is almost complete :thumbsup:
Your s1 looks great. ;) engine bay is awesome. gt30?
MotoMan - is ur front lip geniune nissan or is it aftermarket? coz i find aftermarket lips dont really fit well like the geniune ones, correct me if im wrong :)
Edited by Charles89
Im pretty sure mines genuine nissan..
aftermarket are generally fibreglass, and mine isnt fibreglass
just a few photos of my r33 when a few of us went down to benaraby for the friday night test and tune, had a crap night let just say i wish i hadnt had gone, alot went wrong, but it wasnt with my car so everything is well :D
hope u like the pics.
thanks to blake who took the photos for me.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
