  • 3 weeks later...
^^^^what type and what size are your rims^^^^^
nice ride btw.
there XIX wheels (an american wheel.. nothing too special)
model is X-05
there 19x8.5/245 at the front 19x9.5/275 at the rears
that 33 v spec is awesome brockaz :blink:
post-30201-1208142958_thumb.jpgHere is my skyline its up for sale, make me reasonable offer if interested, if not just check the pics
its turbo, auto, oversized injectors, 0-100km 5.7 secs
77,000km
more pictures available here
www.myspace.com/vice5500 (go to my pics link)
77,000km
4door lov'n nice :D good luck with the sale
77,000km
+ 4 show us more!!
As you wish :)
Absolute PORN! Well done. Any quarter times?
Only with the old motor, 11.8 @ 118mph.
That was with 390awhp, now it has 522awhp (but a broken gearbox haha).
Will have a time soonish...
Edited by Brockaz
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
