Post Up Your R33!
nizmo_freek
Thanks man
Yeah didn't get much of a chance to take many pictures, plan was to take heaps but ended up driving most of the day
I reckon it needs spacers to get a better fit but cbf with spacers so I am just going to slam it and try and keep it legal height. Should look a lot better when its lowered
Cheers Chris. Yep original paint colour. The Series 2 Gunmetal (KN6 from memory) is slightly darker or a different/ more pearl or something. The front of the car has been resprayed though as it had a dodgy front bumper paint blend in the bonnet. Mic @ Micolour fixed that up for me though. Looking at some new rims so it may look a little different soon.
Is it back on the road Al!?
looking good, man it must be nice to have it all sorted... you will have to take me for a spin :(
Yep Nick, all sorted and back in force :D
Feels awesome on the road and could not be happier with the package; 325rwkw with full boost by 3000rpm :P
Next time we meet up, just come and ask for a spin, but best place would probably be at the next DECA. So disappointed that DECA masters has been cancelled :D
325rwkw and full boost by 3000rpm... f%#k me... you must have shares in a tire company;) in gear acceleration must be pretty special... I bet it feels good on the road with the 3L, so easy to drive hey
yeah sad about deca! I might go on the cruise planned for the 28th
heres are some of my brother old skyline which was done by iq auto,, but to bad he sold it to guy that came down from qlds
it got ba headlights
This car was parked close to my house (B**** Cls., Delahey). Always wondered if he was on SAU and what happened to it, as i hadn't seen it for a while.
Exactly Nick! Very easy to drive and VERY tractable on low boost (315rwkw :cool:), also get better fuel economy: 410km/45ltrs.
The boost switch only gives a 15rwkw peak power differance, but the low/mid power and torque increase is just insane and breaks traction in 3th, using in-gear acceleration (ie: use 3rd gear, cruise at 70km, then stomp the accerator: instant loss of traction :down:).
Gear acceleration is just awesome, even fifth gear feels like an acceleration gear.
Of course someone from QLD bought it.
Bright paint, huge kit. All they need now is the silly numberplates no one can understand :dry:
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
    • Sounds like a good idea to me moh
