Yeah it does! I rarely see one with the grey strip down the bottom and in that colour too! Nice one dude! Do you know what the name of the colour is by any chance ive been meaning to find out?
http://www.skylinesaustralia.com/forums/Ni...;hl=paint+codes
the grey is KN6, same as mine. not sure what the green/blue is.
my guesses are:
BN6 - Deep Marine Blue
or
DN0/DH0 - Green Metallic
i know iv seen one with the green all over, it looked absolutely sex. :P
my guesses are:
or
i know iv seen one with the green all over, it looked absolutely sex. :)
Cheers buddy :blush:
front lip on hey mate. what do you guys reckon looks better lower lip on or just front bar all together.? tryin to decide what to go hey.
It depends on the colour, what type of front bar and or body kit and spoiler youve got on it? Pictures would be very helpful!
Taken today. A rare sight that my wheels are not black from brake dust.
Just had the front lowered by some "hoons" at the local tyre place, they got a little excited and lowered the front waaaaaaaaaay too much. Now it's useful for scraping bits of asphalt off the roads, sucks ball$ coz i just had the front re-sprayed.
Will get the front raised a little...
The bum collecting cans out of the trash in the background came with the car, he is a genuine nismo item.
Edited by medman2damax
Hi mate, I'm surprised that you're scrapping as the front does not look too low at all.
Not sure about the decal though and the front light covers...uumm...not my cup of the tee, but other than that, the car looks really neat and tidy...I love your rims!
Cheers mate. I will lose the headlight covers when I get some new ones, I am getting custom eyelids made in the near future.
I love the rims, they are Advanti Vienna 18's, they're a bit unusual. I'm usually into chrome but not on a silver car.
I should have got 19's though, they would have filled the guards a bit more and you can get a 2 inch dish on 19's but not 18's. One day I will sell these and actually get the 19's...
Yeah mate, at the end of the day...it's your car...modify it and do it up as you see it...other people's opinions should be secondary...
Nah, I think 18's are good enough...19's are too heavy and will scrap... no need for this.
Yeah not a fan of the head light covers or the decals. Bit too Need for speed underground for me but each their own i spose!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
