We have way too many sports cars at the moment... those two skylines, which were moved to fit the new supra next to the old supra, and I'm looking at another soon...
And I have to move in like 4 weeks! :/
Nice 33 Simon,
By the way...completely off topic, but do you still get good air flow to your cooler without the front bar cut out like i've seen on others?
cheers m8
i dont really see any adverse effects from not cutting the bar, and i would rather leave the bar as is, just think it looks better?
i would ideally like to fit a longer narrower cooler to improve things, but i have yet to attack that idea, summer job, and see what i can fit?
also thinking about water spray on cooler and maybe nitrous spray bar?
i have a complete with extra bits kit from the wizards of nos, which i took off my 220 turbo, with two 11lb shiny polished bottles :)
where the hell to put em is the next issue lol
cheers m8
Something like this.
I was thinking about buying this and just buy a piping kit.
Are you running standard turbo? Any power increase/lag?
that looks like what i was considering......., no running a hks gt2535 (i think thats the number) bit laggier than std, but 1 bar at 3k rpm, allegedly running 350 bhp? i think its less tho, gotta get it rollered at some point to see :)
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
