Here are a few before + after shots of my R33 gtst. I recently fitted stock bodykit and smaller, less flashy 18" wheels as I'm now using it as a daily (and I was cringing every time I bottomed out :thumbsup: )
Before:
After:
I am currently selling the 19" wheels, explosion bodykit and cannon muffler, if interested check out the links! :)
http://www.skylinesaustralia.com/forums/Fu...dy-t313973.html
http://www.skylinesaustralia.com/forums/19...yr-t315662.html
Edited by bt23
post-7531-1157971103.jpgpost-7531-1157970955.jpgpost-7531-1157970807.jpgpost-7531-1157970593.jpgthis is before the air brushing i am sure everyone has seen it just fitting in with the post so save your comments if you reply is gonna be we have seen it before ?
What are these rims called been trying to trace them down, they gotta look better than my advanti stalkers.
page 6, the black rig it didn't quote properly :(
Edited by 3340TH
Collen, I don't need to tell you how good the car looks, I've told you that enough! But fkn hell your photography is awesome!! Fantastic work mate.
SLYDA, that's the first time i've seen a Bomex kit look good on an R33.
Thanks :)... a LOT of work went into that to make it look how i wanted.. couldnt bring myself too put the series 1 bomex kit on it, and no one had a decent series 2 either (plus near impossible to find)... so it was time to cut up a R34 kit and make it fit, not as easy as i thought..
thanks mate! i took about 100 pics and came up with these 3 or 4 from that night. if you sit around playing with settings on the camera enough you eventually come u p with something.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
