Got some fitment issues up the front. 20 * 8.5 +25 rims.
The wheel is physically too large in rolling diameter and is rubbing on the top suspension arm. So I need to hit the drawing board.
Anyway the test fit...
What are you guys thinking? Improvement or not? I am going to slam the car back to the ground with the new rims, remove the wing, and try and line up a carbon fibre duck wing and roof spoiler.
I think the new rims need a new look...
yea they look hotttt,
slam to the ground, get the duck lip if you want, but i dont know about the roof spoiler i dont really like the look of them
but definently make these rims fit and slam the car to the ground :D
what size tyre on the front?
i like it but i dont know how you'll get around the front lip been a mile from the road purely because of the size of the rim you wont be able to reduce it much.
still nice wheels an all.
ROOF SPOILERS ARE FKN AWESOME.
Yeh im worried this suspension arm might be the death of me!
I took some pics to show it. Hopefully with a 5mm spacer on the front and a stretch say, 215/30/20 on the front. But turning still might pose problems, and I think full lock is out of the question lol.
But I mean come on bulk people have fitted 20s before to 33's (all be it chromies :(), surely there is an easy solution. Aftermarket suspension arm (thats less bulky)?
Oh and the tire on the front atm is a 245/35/20 I think. I wont go that wide on the front with the new tire, which will save me some space... but the new tire will have tread aswell (where thisone is down to the wire), so i fear it will even itself out abit there!
The Cannon Exhaust is about to go though. Looking to cut the tip off and weld something a bit quieter on the end to try and get a crisper less droney note
cool lower lip on the bar man, wheres that from?? accentuates the front even more than normal...which im starting to love :)
Just Jap. Took a lil bit of trimming and adding to fit. Otherwise it aint too bad. Just replaces the factory lip. Gives it more of a sporty look to the front without looking over the top whilst keeping the strength and fit of the factory frontbar.
Luke
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
