i think you should swap the gtr wing for a duck tail if youre gonna add a roof spoiler
Yeah might look into that when i get it
Very nice. What size and offset are the rims??
18x9.5 +20
Vanquish?
yeah :D
what was featured on speedhunters, your car? why?
just a feature i guess :)
http://speedhunters.com/archive/2011/03/03/readers-rides-gt-gt-clean-and-simple-33.aspx
Yeah I know I love it this height. It's all got to do with the width of the rim/tyre as their 8.5" I believe and 245 tyres so their scrubbing on the arm inside and also the guards inside, once I put my 17s on which will HOPEFULLY be this week I can lower it back down to this height but as it is I'm probably sitting 65-70mm from the ground :P
ahhh i see. try some 235's instead? i have 33 GTR wheels (9.0" wide) with 235's on my 33 gtst and they dont look too stretched. getting coilovers tomorrow so i'll see how it sits down over them.
will post up some before and after pics :laugh:
Some cool toys you got there man :thumbsup: that's a V-Spec II yeah?
Thanks man :happy:
And Spot on, has 300 atw, Finally let me take this thing around the block last week, one word; machine!
Edited by kinggtr
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
