judging what a car is by the boot lock is a pretty dumb way to go about things.
every part of the body points to it being a gtr and not to mention it also has a number plate that could only go on a gtr
  • Like 1
So you're meaning to tell me, that there is no absolutely possible way that a gtst could imitate a GTR...? and yeah let's not forget another dead give away, how could I miss it. The number plate that "could only" go on a gtr!
even though my gtst has a gtr wing -it was already installed when i bought the car. i still dont understand why people spend money on making their gts/gtst's look like a gtr, maybe to make it "fully sick"......just buy a f**king gtr
  • 3 weeks later...
Mah I'm more going to be using them as drift wheels anyway. Was just checking so make sure they would fit.
However I have got new wheels & I'm fairly prepared for the hate from people for them.
5ca98e106274ec3088eac3cd9cfe7059_zpsc20d
9acd0b9ac76c68b39b574414f9fd1f70_zps00e3
& just a couple of random pic's.
3cb0e284e4ae66de8980ada64ec03b80_zps5d68
4546f2642984d408ab10ea9c5368c824_zps3041
4b732348af9fdb1be2aadcfa65772751_zpsb1df
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
