Cheers!
I went with a conservative 18x9+30 and 18x10+38. Sits flush, factory body, guard roll not required :)
Car Looks Very Nice! :thumbsup:
I've got some xd9s in bronze at home waiting for rubber, have gone with 18x9+20 all round. So keen to get them on!
Hurry up! Keen as for final result.
Anyone with pics of a 33 sitting on 350z rims?
I know this is an old request/post... But...
My 1995 R33 4 door has 350Z rims, I reckon it scrubs up really nice. (Especially when they're clean)
I do have lowered suspension, but will soon be raising it again.
Edited by jamesnorman93
I never get sick of seeing that Rob! :thumbsup:
Cheers mate! Funny you should say that... My current screen saver is the pics from Wakey when we went up.
This one Always catches my eye. Hope you don't mind. ;)
  • Like 1
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms and my car is lowered a bit (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
