We're is power play at how much does it cost to get on the track? Do you need a cams lic??
Powerplay/Powercruise is pretty cheap really. The earlier you enter and pay the more discount you get. Starts at $80 then goes to like $200 + if you register on the day.
This fee gets you access to the track, only need a normal drivers license. They have different events that run through out the day.
Cruising Sessions [Happy Laps]
Drifting
Off Street Racing [Drag Racing]
Power Skid Comp
Burnout Comp
You need to wear full length clothing [Jeans & Longsleeve shirt] Shoes & Helmet for all events but the cruising sessions
Definitely a great day out
How's the old girl going, I will need to grab a copy of zoom to catch up on all the new mods, have you got to 10 yet and have you had it to any tracks yet?
I do miss the thing, rolling in the 5 with about 75 atwkw doesn't have the same effect as the old line
pulling through the gears.
sime1, post 5000, is that a spelling mistake. "every component helps separate this example from its taxi lineage just that little but further"
the underlined but, should it read "bit".
congrats on making the mag also.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms and my car is lowered a bit (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
