This is how the tail lights actually look. My Canon EOS 600D seems to love sucking in light on the auto setting with no flash. Any advice on a better manual setting for twilight pics would be good. The shocks are just KYB Excel-G with standard springs as far as I can tell and 225/40ZR18 tyres.
Flash off, low shutter speed and then play with apature to get it right. Use a tripod if you have one.
Repost from a few pages back, but this photo is taken on a tripod with these settings
shutter speed - 10sec
apature - 5.6
iso - 100
14137614291_415cb839ef_b.jpgEdit-3155 by 89CAL, on Flickr
The best way to learn manual is to just do it. Your going to take bad photos but thats the good thing about memory cards, easily deleted. The canon's are good because you can switch to on screen view and play with settings there to make the picture look O.K.
  • Like 1
Nice! Mine mysteriously had the Rear changed to S1 somewhere between Japan and here. :/
I had to change it back to S2 but could only find Black at the time. I may or may not get them colour matched oneday.
^^^ You suffer from the same problem as me.......good car but bad camera......also why is your wing tilted upwards so much?
Following the rules - I should not chat and post pictures only
so here goes...................
Missing my car......been a week :/
10564828_10154402221930099_261796288_n_z
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
