I'm letting my pride joy go for $26000up for sale is my pride and joy, high powered performance gtst. which is also featured in the zoom magazine, previous owner had set this beast as a track car, also spending a lot of $$$ on it has one at import monster sau nats 2012 for quickest 800m mod 2wd class.
also at import monster sau nats 2012 800m highest speed mod 2wd class.
there is no back seats and carpet had been removed, has a bonds half cage $700 installed
has two r34 gtr bucket seats.
gtr rear end
omp race spec stearing wheel
a set of $700 defi din gage for oil,press,water,oil,temp
has a zetronic ethanol display screen $500
nismo gtr 320km cluster white $1000
phantom boost gauge $220
fully enginerrd certificates so hassall free
motor rb25 30 to4z turbo water and oil cooled
2000cc injectors areo flow fuel rail
all braided lines runs from engine to the boot and connects to a 5 ltr sard fuel surge tank with x2 walbro 450 in tank pumps
nismo in tank fuel pump to exterior
has an immobiliser built in too
x2 fuel location for exterior pumps
also has an e flex sensor so you can use petrol or e85 sensor and computer does the rest.
huge plenom with qhf 90 mm throttle body
Ross cas full balanced
drilled out oil remains blow off is plumped back
blisten shocks all new bushes
sway bars in boot engine bay under Neath sway bars
r33gtr wheels with brand be hankook tyres $1500 for set of 4
response head unit alpine speakers
brakes upgrade to dixcel type gs slotted rotors with zpads $2500
has also just put in a PPG dog box 1st to 4 gear straight cut 5 normal gear $8500
also has a nismo twin plate coper mix clutch but good friend jim berry had it supped up for me costing $3000 but strong guarantee it will last
r33gtr rear end 4:11
also eagle conrods, je pistons, custom exhaust camshaft (256deg) single coil up rated springs drain back vents on head drilled out oil returns rb26 cam covers with mines baffles external oil feed1mm restrictions full balanced QF45 throttle body high energy oil sump, tomei oil pump, factory Ross cass balancer, gready intake manifold, custom front mount inter cooler, Phoenix alloy radiator, custom 3.5 inch 5zigen exhaust system, high current igniter, link g4 plug in engine management system with link 2bar map sensor gready profec and electronic boost controller
the whole e85 fuel system cost $7600
car mad 450kw 601hp ran 11.08 at creek with old box be easy 10z with new box
car has receipt for every thing no joy rides no time wasters $27000 no less over 60k worth of grunt and power munches any thing on the road on low boost.
car also is featured in zoom mag custom plates SKYLNE also has 3 boost settings off is 14 psi low is 21 psi and a high 26 psi
call me on
0437797237
powererd and tuned by unigroup enginering!..
Edited by sime1
It needed a strong box, the big block sized torque ate the standard Nissan gear sets.
I see it also has FLEX fuel and supporting mods.
How much torque is it running now, do you have a dyno with torque and rpm, I would imagine it would be pulling stumps from 3k to 4k rpm.
  • 3 weeks later...
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
