Pulled the gtr out of storage today so I can clean out the shed..
Looking very sad panda I know.. Paint and panel will be its xmas present! (and a wash)
cant believe you were thinking about selling it... ;)
Hahah yeah... I'm not really using my head am I.. I don't want to post pics of it as i am unhappy with the way it looks
for xmas its receiving vented bonnet, n1 bonnet lip, respray and PDR touch up.. tune my coilovers properly (and lower it a touch more)
service it and give it a good long drive
atm though makes me sad panda looking at it in my garage all neglected like..
Erick that looks awesome!
Engine bay looks abit tame tho :P What turbo etc are you running?
Wasnt going to say it but my exact thoughts, every part of the car has had a lot of time and money spent on it to make it look something special and then when you pop the the bonnet it almost looks like someone has taken a turd in the engine bay (not really that bad but with the rest of the car done to the quality it is the engine bay looks really bad).
A short videoclip before re-map and dyno.. Car is much faster today.
Here's the spec
Engine spec and transmission
HPI Stainless extractor exhaust manifold
HKS GT 2835 ProS Turbo Kit
HKS heatshield over the turbo
HKS downpipe
HKS hard pipe kit
HKS cam adjust pulley
HKS Mushroom open air filter
Z32 80mm AFM
Greddy FMIC
Greddy intercooler-pipes
Greddy Type RS blow off valve
Greddy oil filter sandwich
Uprated injectors (TBC)
Uprated fuelpump
Tomei timing belt
Adjustable BTR
Race Clutch tripple plate
24 row oil cooler
Blitz racing water cooler
Silicon radiator cooling hoses
5-Zigen exhaust with de-cat
NGK Iridium Spark Plugs
Apexi Power FC
Nismo LSD
Handling
Aragosta Coilovers
Strut bar in front, self-made
Brakes
Greddy GREX 4-pot brakes 330mm in front
Wheels and tires
18" Ultralite GT-II Black
-8.5" in front
-9.5" in rear
Toyo Proxes T1R
-235/40R18 in front
-265/35R18 in rear
Interior
Recaro seats
-Drivers seat FIA approved
-Passenger seat folding
Takata 4-Point Seat Belt Harness
Blitz Gauges
-Boost Meter (2.0 bar)
-Pressure Meter (Oil)
-Temp. Meter (Oil)
-Temp. Meter (Water)
Digital LCD Boost Meter
Greddy Turbotimer
Blitz BoostController
Ultra digital LCD speed/rpm meeter
MOMO Race steering wheel
Räzo shift knob
Hole interior is flocked.
Stereo
Jensen VM 9022 HeadUnit
JBL GTO4060 Amplifier
Infinity Reference Speakers
-6510cs kit in frontdoors
-6512i koax in rear
DLS Reference W710 Subwoofer
Exterior/styling
Full JUN-kit
GTR wing
Wide front fenders (fiberglass) with removed side indicators
Carbon bonnet KR-style
Carbon Grill
Carbon Blade for the GTR wing
All carbon has red flake! And 10 layers of clear coat.
Boot lid cleaned, no keyhole
Xenon converted (8000k)
LED-stripes in the front lamps used as parking lights
Styling tail lights
Spoiler mesh from BMW E46 M3 CSL
Painted by PaintWorX
Thanks to
Everybody in Evolution Garage (www.evolutiongarage.se)
Paul at PaintWorX (www.paintworx.info)
My girlfriend Sandra (www.garaget.org/missmums)
Cajs Bilverkstad i Elofsrud (www.cajsbilverkstad.se)
About the enginebay, there just wasnt time to fix that before all shows that Ive been to this summer.
I have a project thread if you want to read about the built
http://www.skylineowners.com/forum/showthread.php?t=100570
Edited by Erick
+1 build me some and send them to me and i shall pay you :P
Very nice car buddy, im currently reading your thread, love it.
EDIT: Hahaha you put in HID reverse lights! Now i've seen everything!
Edited by PM-R33
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
