Its clean untill you go in it and crap yourself. Thats how quick this thing is. This car is awsome. Love it Jack.
Haha, thanks Pete, saw your car at Dom's the other day, I like what you've done with the calipers, looks really good, especially hiding behind those BBS LM's....
The car looks really neat, will have to go for a drive one day...
What type of bonnet is that ...Carbon ???? Who makes it ??
Assuming your asking me, it's carbon over FRP bonnet made here in Aus. Bought it from Unique Autosports quite a few years back but they can't get them anymore....
I have seen them on Yahoo Auctions though....
JAGR33:
Jack,
One of the best looking R33 around, speechless!
Matt
Thanks mate, especially coming from someone who would have to own the best GT-R in Aus, if not the world.... :P
+1. That looks so fkn hot
Cheers... :blush:
Thanks for the kind words fellas! :cheers:
The wheels are Blitz Technospeed Z1's
17x8 +35
17x9 +38
they're actually pretty rare and I havn't seen them on another car...ever lol It's just a shame about the offsets.
As for suspension it's on Bilsteins/Tein S tech's. I'm not sure about what coil-overs are going to be as cost effective
or give as comfortable ride (it's a daily driver)
Anyway here's another shot to show the offset
Thanks for the kind words fellas! :P
17x8 +35
17x9 +38
just so you don't think you're the only one in Aus with them :D
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
