Taken by Matt last week at the Legends dinner. :cheers:
When the sun gets so low that a pinkish hue is emitted over everything, the 'softened white' of your car draws you in doesn't it?
The timing has to be perfect!
2 minutes later and it's gone!
My newish 33 :)
HOLY CRAP! I was set to buy this exact car a couple of years ago, booked flight from Hobart to Melbourne to go and inspect it, and the guy sold it the night before I was coming over! I ended up with something almost identical anyway...
Series 1 interior yeah?
Semi-as promised: Car didn't leave the garage, but I did take a few quick snaps: This thing is quite dark in the shade but is VERY vibrant in the sun. Minus the peeling clear coat near the boot, unfortunately.
The OWENs have it!
  • 3 weeks later...
yup, those are buddyclub P1's, seen a few other 33's with those shoes on too.
not sexy deep dish things but light enough for the track, yeah the plates have got me pulled over a few times but no defects so far...knock on wood!
Lol. It is now a work in progress again. All in the name of getting more tyre.
This rear Kit is nice post up some finish shots this is something i would love to do to my car.
if you dont mind me asking who did you buy this from?
From Viva Garage. Ive heard mixed opinions so I bought expecting to modify fairly heavily but you know what. It is actually going together quite well. Cut about 1 cm of a hidden part of fibreglass off to clear the headlight, Thats about all and its gonna fit like a glove with minimal gaps. May need a very minor trim to clear the door. But its very close.
Only question being with the rears. Do I leave it with just the lower portion widened. Or do I pack it right out and completely round off the rear quarters. My mind is halfway between both options.
It's looking very nice Luke!
For the traditional look you know the answer.
For an individual look it's the other answer.
And I don't think it would detract from the value of the car should you sell it further down the track - especially with a good choice of wheel.
As for me?
I don't mind either way.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
