Post Up Your R33!
nizmo_freek
thanks for the pic david
its good to see the response on the car.. makes you feel like all your hard work finally pays off
Are your front gaurds flared or rolled???
what size are your rims?
Only asking coz i noticed you are using 25 or 30mm spacers
Jayson, I was at the showcase and your car was definitely one I couldn't stop looking at! Awesome work on such a tastefully modified r33 gtr.
Here's the latest pic of my 33:
Looks good Brad, was following your build on JDMST till the pricks banned me lawl.
Anyway, here's my shit heap, bought it a month ago. Atm it's not pretty, but puts out the second you ask.
Plans cosmetic wise is a new kit, wide rear guards, roof spoiler, new rear spoiler, new wheels etc etc.
Probably wont happen till next year though, as I've already entered a few more drift events this year and I can see me f**king shit up >_<
hey mate where did you get those stickers from, look really nice an vibrant.
Stickerbomb!
You can buy stickerbomb sheets nowadays from ebay . Saves time.
cheers, what size sheet did you buy?
and how hard is it to take out that section, last time i tried i thought i was going to break it.
Front detail shows some chipping and such. And yes I know I need to get some Xenon Headlamps!!!!
This is one way to stand out from the crowd, good job .
Car developers do "kinda" similar decals to vehicles that their still testing in the nurburgring.
Have a look on ebay bud and they'll specify sizes , theres a tutorial in removing interior panels on here, just search.
9tro posted this car on FB the other day...was old pic with the white wheels though..
xenon lamps would be nice but just polish your headlights for now......
just get a buffer and some cutting compund on them and they will look like new .... :thumbsup:
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
